- Oct 11, 2021
Foresail rigging finished
Hi guys!
Quite an update today with lots of pictures, 24 to be exact. It was not easy to get everything right in front of my camera. I have all running rigging of the Foremast ready. I really had some trouble rigging this sail. Some things I had to redo over 3 times or didn't turned out the way I wanted it and was pretty exhausting from time to time. Also figuring out the details cost me a lot of evening hours of work. Unfortunately in all the documentation I have the details are vague or not known. I followed the rigging of Le Requin in combination with another Xebec (museum model). In the end you make choices that seem logical and I tried to keep as close to reality as I could or know.
The parrel
It starts with the Parrel. The parrel is like a "guide system" that actually rolls the rod / yard up and down the mast. The parrel is made up of so-called "trucks", these are the beads and "ribs" the vertical pieces of wood. As always, I start with a drawing to the actual scale. Then I make it as on the drawing in various steps. Oh yes, the ribs that come with the kit are made of metal and also the wrong size. So I haven't used it. Each rib is individually handcrafted. Builders with milling machines can do this faster and easier than I can, but the admiral won't allow these machines on her dining table and that's the end of the discussion....
The parrel is finally assembled with the made ribs and the trucks of (3mm) and attached to the yard. The parrel of this mast is a simple version. Just 3 horizontal rows that are spliced together and extended into one single rope. On one side of the yard, a strop is used to attach it to the yard. The parrel is wrapped around the mast and then attached with a truss by using a bead the other side of the yard. (see second photo). For the main mast I'm going to replace this bead with a block. Finally the rope runs down at the mast to the foot of the mast where it's tied down using a tackle with a few blocks. This can be seen in the following pictures.
A lot of lose ends here....
The parrel tackle is seen on the picture and is the one with the dark ropes next to the mast. The other two tackels are used to turn the ends of the yard. The ropes are running throught the top sheeves on the mast. These tackles are attached with a hook to the rings besides the mast.
In between I made the flagpole. The flagpole is attached with two metal braces.
then a picture of how it looks in full view of the sail.
And a lot of detail pictures of how I tied down all the ropes.... All rope ends are nicely bound together and tucked away...I tried to mimic reality as much as possible and hopefully the rigging is truthfull to the real thing....
And that's it for this update. I know, sometimes I can't see the forest because of all those ropes. The mainsail will carry the same amount of rigging.
Only the rigging of the Foremast took me approximately more than 40 hours of work / time. I can only say that it is a big job and the same is waiting for me for the rigging of the mainsail. I have to finish the construction of this sail first, put the boltrope on and so on. I hope you enjoyed this update.
Until the next update, and I wish you guys a nice weekend!
Peter
Hi guys!
The parrel
Peter
