Whaler RAU IX 1 : 45 - Graupner
Small upgrade
The small ladder is also attached to the chimney and the chimney is now finished. Finally I painted it with matt clear varnish.
Then I started with the lifeboats and the associated conditions.
Well, the beginning has been made.
First the 1 mm holes were drilled into the deck and the first supports were glued in, at least until the first arch came into the railing, then support by support was pulled onto the railing and glued into the hole.
By the way, the railing was pretty bent.
I clamped one end in the vice and the other end in the cordless screwdriver, then held it tight and twisted the wire until it was straight. Works really well
Small upgrade.
The supports for the footbridge have also been adjusted and installed.
The footbridge is still lying loosely on the supports.
Then I attached the first part of the handrail to the bridge wall
