Well done Fish&Chip,I tried to make two turnbuckle with my Dremel. I do not know what to do now, since I found the result mitigated. I do not have yet a Proxxon Milling Machine.
Thanks NMBrook, I tried with the smallest files I have. They are not thiny enough and measure 1,45 mm in thickness. Do you have a recommandation for thinner files ? Nearest 1 mm in thickness ?Looking at your pic, all the slot needs is a light dress with a small jewellers file.
Needle files and/or AmazonUnfortunatly, there is no hobby store with sufficient stuff in the inventory to found these very small files required, regular mini files are in stock. So, I wiill have to grind one or serching on the web, but where and with what keywords.
Efectivamente, no depende de la Dremel, sino de la herramienta que vaya a utilizar.Sí, lo es, usaría una fresa tipo bola de 1 mm. No use una fresa de diamante, el metal blanco simplemente se pegará y usará una velocidad baja.
Saludos cordiales
nigel
