Where can I get a printable 1/36 scale conversion chart in inches/feet and mm/cm ? I'm not converting inches to metric, just 1/36 scales. I want a chart that's only 1/36
maybe this can be of some helpWhere can I get a printable 1/36 scale conversion chart in inches/feet and mm/cm ? I'm not converting inches to metric, just 1/36 scales. I want a chart that's only 1/36
Give me an idea of what you want (like a pic of a similar chart in another scale) and I'll make you one in Excel (which can then be printed) or make you a PDF.Thanks I have these. I need a chart. There must be one there is in other scales.
Yes but the chart is easy reference. Don’t have to do the calculation every time.That's an oddball scale. You may have to make your own. I usually just scribble the conversion factor on whatever plans I am using and keep a calculator handy.
Like this only in 1/36. Can’t find one anywhere. ThanksGive me an idea of what you want (like a pic of a similar chart in another scale) and I'll make you one in Excel (which can then be printed) or make you a PDF.
No problem. Give me a few minutes. Although, do you really want fractions listed in 18ths, and 72nds and other things no ruler has? Or the closest 1/64" or what?Like this only in 1/36. Can’t find one anywhere. Thanks
Thanks !I have several conversion charts, including a conversion chart for whatever scale you plug is, available at:
