- Jul 26, 2013
I picked up a Dremel Model 280 table saw at an estate sale and it is really pretty nice! The motor looks like a sewing machine motor but has a lot more power. I've only cleaned it up and made a few cuts but it seems like a nice little machine. Like any little saw, set up is going to be key for accurate cuts. The fence and miter gauge are OK, but I wouldn't trust them to stay put but that's what squares, clamps and 1-2-3 blocks are for. It takes 4" blades with a 1/2" bore which are relatively easy to find from MicroMark and elsewhere. Additional replacement and upgrade parts are available from:
The tilting arbor and blade raising.lowering mechanisms work well. The whole body, table included, is some kind of sturdy plastic. These were also sold under Sears and Montgomery-Ward names in the US and Canada. The throat plate is sheet metal, BUT seems to be the same thickness as Formica sheets when you need to make zero clearance inserts. 3-D printed plates are available from radicalRC, above. The motor seems higher quality than the current Micromark offering. If you see one, I would pick it up! Just my first impressions...
Tools & Equipment - Table Saw Dremel Accessories Radical RC
Tools & Equipment - Table Saw Dremel Accessories, Dremel Table Saw Replacement Belt , Dremel Table Saw Miter Gauge , Metal Cut Off Disk for Dremel Table Saw Radical RC Electronics for all hobby needs.
www.radicalrc.com
