monty corey paddle boat
shelton ct
MYRTLE COREY PADDLE BOAT..i just cannot sync paddle wheel linkage to motor gear. i have gear starboard side set both gear & paddle wheel in 12 o'clock position. port side both at 3 o'clock position. starboard side jumps all over. constant adj rod adj at 3 & 9 position. either too short or too long. wheel turns with jerky motion. i have tried numerous adjustments. any-one live near ct. usa. i can bring boat for you to look at. using brass 1/16 rod. too flexible??? thank-you * (information removed by Admin due to publicly broadcasting personal information)
Welcome aboard SOS! We have a couple of members build paddle-wheeled RS boats. I am sure they can help you with the resolution.
i just cannot sync paddle wheel linkage to motor gear. i have gear starboard side set both gear & paddle wheel in 12 o'clock position. port side both at 3 o'clock position. starboard side jumps all over. constant adj rod adj at 3 & 9 position. either too short or too long. wheel turns with jerky motion. i have tried numerous adjustments. any-one live near ct. usa. i can bring boat for you to look at. using brass 1/16 rod. too flexible??? thank-you warner
