Transcription of the Report:
Lloyd’s 1846 Survey of the Barbara
# 7803
Survey held at Liverpool
Date Nov 6 1846 (Received 12/11/46)
on the Barque Barbara
Master Mackay
Tonnage 418/459
Built at Halifax in 1846 by Lyle
Owners Pearse & Co.
Port belonging to: Galway
Destined voyage New Orleans
Surveyed in dry dock and afloat
Length aloft: 110’ 0/10 Extreme breadth: 25’ 3/10 Depth of hold 18’ 4/10
Scantlings of timber
Timber and space 24“ each
1st Footbooks: 11 1/2” sided 13 moulded
2nd Foothooks: 10 ½” sided 9 ½” moulded
3rd Foothooks: 10“ sided 8” moulded
Deck timbers: 9” sided 9” moulded
Deck Beams: (No. 17) 11” sided 10” moulded
Hold beams: (no. 16) 12” sided 11½” moulded
Keel: 12” sided 10½” moulded
Kelsons: 14” sided 25” moulded
Thickness of plank
Outside Inside
Keel to bilge: 3” Foot waling: 5½”
Bilge planks: 4” Bilge planks: 5”
Bilge to wales: 3” Ceiling in flat” 3”
Topsides: 5” Ceiling bilge to clamp: 3”
Sheer strakes: 4” Hold beam clamps: 5”
Plank sheers: 4” Deck beam clamps: 4”
Water-ways: 7” Ceiling ‘twixt decks: 3½”
Upper deck: 3” Hold beam shelfs: 14” & 5”
Deck beam shelfs: 12” & 5”
Size of bolts in fastenings, distinguishing whether
Copper or Iron Copper or Iron Iron
Heel-knee and dead wood abaft: copper Bolts thro’ the bilge and foot waling: Hold beam
Searphs of keel: copper Butt end bolts: Deck beam
Floor timber bolts: copper Lower pintle of the rudder: 2¾
Kelson bolts: copper
Transoms and throats of hooks: copper
Arms of hooks: copper
Timbering: the space between the floor timbers and lower foothooks in this vessel is 1 inch. The space between the top timbers is 3 inches. The stem, stern post, are comprised of aftrican ??? & birch. The transom, aprons, knight heads, hawse timbers of ? oak & ? pine and are free from defects.
The floors and first foothooks: birch
(A number of designations are left blank)
The main kelson is comprised of spruce and the false kelson of birch
The searphs of the kelson are not less than 6 feet
The deck and hold beams are comprised of spruce
Planking outside
From the keel to the 1st foothook heads: birch and spruce
From the light water mark in the wales of yellow pine & spruce
The wales and black-strakes: red & yellow pine. The topside of: yellow pine & spruce.
The sheer-strakes and plank-sheers: oak & yellow pine. The water-ways of yellow pine
The decks of yellow pine (state of good)
The shifts of the planking are not less than 5 feet. The planking is wrought 2 & 3 between
Planking inside
The limber-strakes are comprised of spruce. Between decks spruce.
Shelf pieces spruce. Clamps spruce.
Fastenings
(Cannot read)
Her masts, yards, etc. are in good condition.
Sails: Cables
s
2 Foresails 240 fathoms Chain 1 3/4 “ Bower 23 – 1 – 3 22 – 0 - 14
1 Fore top sail 80 fathoms Hempen stream cable 7 ½”
2 Fore topmast stay sail 75 fathoms Hawser 5”
1 Main sail Warp 4 ½”
2 Mail top sails 7 fathoms
And full ??? in other sails
She has 1 long boat and 2 others
The state of her windlass, capstan and rudder are good.
Surveyor: William Pope
Classification: A1 for 4 years
