Hi fellows, could you recommend suppliers for good quality cannon balls ? With small diameters around 2.4 mm ? Thanks
Check this out, LuizHi fellows, could you recommend suppliers for good quality cannon balls ? With small diameters around 2.4 mm ? Thanks
Gun | Diameter (In) | Diameter (mm) | 1/96 |
64-pounder | 7.55 | 191.77 | 2.0 |
42-pounder | 6.84 | 173.736 | 1.8 |
36-pounder | 6.7 | 170.18 | 1.8 |
32-pounder | 6.4 | 162.56 | 1.7 |
24-pounder | 5.82 | 147.828 | 1.5 |
18-pounder | 5.3 | 134.62 | 1.4 |
12-pounder | 4.62 | 117.348 | 1.2 |
9-pounder | 4.2 | 106.68 | 1.1 |
6-pounder | 3.67 | 93.218 | 1.0 |
4-pounder | 3.2 | 81.28 | 0.8 |
3-pounder | 2.9 | 73.66 | 0.8 |
Or a box ofshotgun shells (25 ea)A friend shoots trap and skeet, and just happened to have steel shot in sizes very close to what I needed. Problem is, if you don't have a friend, you probably have to buy a pound of shot to get the gram or so you need.
You'll need to know the size....I think that if you went into a gun shop and told them that you need 2 grams of shot they would probably give it to you. Or go to a range after a shoot and drag around a magnet.
Gun | Full Size Diameter (In) | Full Size Diameter (mm) | 1:96 Scale (mm) | 1:84 Scale (mm) | 1:75 Scale (mm) | 1:64 Scale (mm) | 1:48 Scale (mm) |
64-pounder | 7.55 | 191.77 | 2 | 2.3 | 2.6 | 3 | 4 |
42-pounder | 6.84 | 173.736 | 1.8 | 2.1 | 2.3 | 2.7 | 3.6 |
36-pounder | 6.7 | 170.18 | 1.8 | 2 | 2.3 | 2.7 | 3.5 |
32-pounder | 6.4 | 162.56 | 1.7 | 1.9 | 2.2 | 2.5 | 3.4 |
24-pounder | 5.82 | 147.828 | 1.5 | 1.8 | 2 | 2.3 | 3.1 |
18-pounder | 5.3 | 134.62 | 1.4 | 1.6 | 1.8 | 2.1 | 2.8 |
12-pounder | 4.62 | 117.348 | 1.2 | 1.4 | 1.6 | 1.8 | 2.4 |
9-pounder | 4.2 | 106.68 | 1.1 | 1.3 | 1.4 | 1.7 | 2.2 |
6-pounder | 3.67 | 93.218 | 1 | 1.1 | 1.2 | 1.5 | 1.9 |
4-pounder | 3.2 | 81.28 | 0.8 | 1 | 1.1 | 1.3 | 1.7 |
3-pounder | 2.9 | 73.66 | 0.8 | 0.9 | 1 | 1.2 | 1.5 |
Mass of Cast Iron ball (lb) | Diameter (in) |
4 | 3.05 |
6 | 3.49 |
9 | 4.00 |
12 | 4.40 |
18 | 5.04 |
24 | 5.55 |
32 | 6.10 |
42 | 6.68 |
