Hello, I've been trying to bend some 1/16" square sticks to 90 degrees to make Davits for lifeboats. I got it done by steaming and boiling them in water then using a crimper but it seems there should be an easier way. Any suggestions?
If this is your chosen method for bending, consider a bending iron like thse used for guitar making.you are doing right
Any suggestions?
what i found out soaking the wood in hot water and bending it does not produce steam and it is the stean that does the bending
here is my way of bending wood.
i have a wood burning stove and the pipe stack gets quite hot, so what i do is just wet the wood and bend it around the hot pipe it creates instant steam the moment the wet wood touches the hot pipe. i will rewet the wood and bend it again until i get the desired bend.
most people do not have a wood burning stove so heating up a metal pipe or can will work.
go here
bending wood
there is enough information scattered all over this and other forums about bending planks. I thought it might be a good idea to cover the subject all in one place. so starting with the PDF file there are a few basic rules 1 not all wood is bendable some bend easy while others no matter what you...shipsofscale.com
Wish I’d had this tool when I built my first and only plank on frame boat. I definitely would have gotten it.If this is your chosen method for bndig, consider a bending iron like thse used for guitar making.View attachment 332157
+1 for the StewMac bending iron. I have one and it works great. Just remember to wear a gloveIf this is your chosen method for bending, consider a bending iron like thse used for guitar making.View attachment 332157
HiIn such situations I use styrene plastic strips. Easy to bend, looks good, can be painted if white is not the preferred color, hard to perceive the difference to wood. I use styrene plastic shaped strips for many ship model applications…especially moldings and building stern quarter gallery structures.
Dave at Lumberyard listed the best direct source for styrene plastics. Evergreen. Thanks Dave! What I did is ordered a dozen different size strips and I keep them handy along with left over wood to grab when building a model and I need to kit bash something. Evergreen stocks styrene shapes in scale so you can select in the scale (or very close) you need.Hi
Thank you for responding, where would I buy styrene plastic strips?
Many local hobby shops carry Evergreen. If you’re in a rush you might want to look there. The web might have better pricing options.EVERGREEN SCALE MODELS
EVERGREEN SCALE MODELS IS THE FOREMOST PRODUCER OF POLYSTYRENE STRIPS AND SHAPES FOR MODEL MAKERS ARCHITECTS, AND ARTISANS AS WELL AS THE OEM MARKET.evergreenscalemodels.com
