- Dec 3, 2022
This is what my model looks like this morning.
She has a terrible skin disease - the mange!
Close up you can see that the varnish has been discoloured by the copper, and then has begun to crack and peel away.
It flakes off quite readily. I can wipe away the flaking material without problems but there are more areas where the varnish is discoloured but at the moment, soundly attached. To remove that I will have to use alcohol which may cause the copper to peel away from the hull in places. Removing all of the copper is impossible - It takes minutes to remove a single plate because it is so fragile and tears into tiny pieces. I am tempted to paint the whole thing brown, following application of a suitable metal primer.
Does anyone have a better suggestion?
