Just wondering if anyone has a rope walking machine and feedback. I am looking to purchase one and was wondering if they work well or not.
While this one is better to your taste, it made to make large size ropes. I don't think it will be suitable for models making ropes. But you can utilize the concept. Frankly...they pretty much designed using the same concept. Be aware that there 2 types of making machines in general, vertical and horizontal. Vertical works very simple, the gears mechanism mounted somewhere at the top, the strands (threads) tied to weight at the bottom.Once on the topic in youtube all sorts of interesting stuff pops up.
Here's one that appeals to my 'KISS' way of looking at things.....
It will be tough to explain with my broken English. The commercially available threads for the most part are OK. Thread is a very, very thin string typically used for crafting/sewing, whereas the rope is made of multiple twisted strands of threads. Also, threads are available only in certain thicknesses and look oversized for scale models they are not twisted like ropes. Another factor is color. Self-made rope can be of any color you possibly want.What I don't understand, if one is starting with commercial thread, which is already twisted, why a motor each end?
This 'gizmo' is one of those rope machines that can make 'endless' ropes. Typical rope machines can make ropes only in certain lengths while the one in the photo can make a very long rope (as long as enough threads in the spools.what about this "gismo"
Posts 10 to 12.
Thanks guys, but these admittedly fantastic machines are way beyond what I can afford, which is why I'm looking for home built ideas.
Thanks for the information. I think I am ready to pull the trigger on either the Domanoff PL4 or the Zhl one. They seem to be about the same.I have to correct my earlier post - it is not Romanow -> it should be off course DOMANOFF
Model Tools And Supplies | ShipWorkshop
ShipWorkshop is a workshop where we design and produce special tools and supplies for ship model builders which will make your ship model look authentic. We'll be glad to help you to design custom tools for your needs. Mechanical and electronics engineering are available.shipworkshop.com
PL4 "endless" rope making machines with traverse are intended for making professional model ropes:
- 2-, 3- or 4-stranded;
- With/without the core;
- Plain laid or cable laid;
- Left or right lay.
PL4 series "endless" rope making machines with traverse | ShipWorkshop.com
Fully automated ropewalks with traverse (rope making machine). Minimal control is required. (Check this video on YouTube for how it works. Turn on subtitles.) PL4 "endless" rope making machines with traverse are intended for making professional model ropes: 2-, 3- or 4-stranded; With/without...shipworkshop.com
or
6+1 rope making machine (high volume twisting machine)
High volume 6+1 rope making/twisting machine with traverse is intended for making professional ropes:
- 2-, 3-, 4- or 6-stranded;
High volume rope making machine (twisting machine, ropewalk) | ShipWorkshop.com
Fully automated ropewalk with traverse (rope making/twisting machine). Minimal control is required. (Check this video on YouTube for how it works. Turn on subtitles.) High volume rope making/twisting machine with traverse is intended for making professional ropes: 2-, 3-, 4- or 6-stranded...shipworkshop.com
I think there are minimum two differencesThanks for the information. I think I am ready to pull the trigger on either the Domanoff PL4 or the Zhl one. They seem to be about the same.
Only the 'cable' work rope, requires a core. The core usually used with 4 threads, where the core is just in the middle.is it important to make ropes with a core?
I may be wrong, but as I go through the list of ropes required for my current model, I can't think of anything that needs a cable laid rope. Maybe the stays?Only the 'cable' work rope, requires a core. The core usually used with 4 threads, where the core is just in the middle
