THANK YOU SO MUCH PETER I will try that, hope you are avaible if I have more questions. Don
It is great for miniature work (small scale ships)!!!have the same Proxxon milling machine, and its ideal for the model ship builder.
@Norway and\or @donfarr Knut and Don, My tutorial in no way to promote\advertise Proxon mini mill, though it is a good tool! It just happened that I don't have Drill stand and XY table combined and set up as Milling machine. The same results can be achieved by using either device as the milling principles are the same.or do YOU NEED THE PRXON MILL
Hello, my friend, Don. As far as I can see, your drill press all set up and ready to make some dust. Let me ask you: did the XY table tight to a base of your Dremel drill? I hope the answer is yes! Now, take off all of your step clamps and attach your milling vise (you mention that you have it).how to lock the press in a fixed position, also how does the T nuts work are they suposed to lock in like the aluminium ones mine I can not lock them in they move, also WHAT DO THEY MEAN WHEN THEY SAY LOCK IN THE ZERO and HOW DO YOU DO IT, also my unit has a little side to side rock and the X part is hard to turn the little set screws I can not turn with my ALLEN WRENCHES, could use a lot of help
