Gokstad Viking Ship by jack.aubrey - Dusek Ship Kits - 1:35 Scale [COMPLETED BUILD]
Cinisello Balsamo (Milan), Calci (Pisa)
Gokstad Viking Ship, Jack.Aubrey, Dusek Shipkits, 1:35
It seems that for at least one year, but could be even longer, I'll spend two/three months in Cinisello Balsamo (Milan)
, in the house that I own since more than forty years, and two/three months in Calci (Pisa) in the house of my daughter Silvia where, being currently single, she has plenty of space to guest me and my wife, with mutual synergistic satisfaction.
Therefore, by accepting this situation, there is a problem with my shipmodeling activities: in my house I've set up a quite functional workshop, where I am currently building the "Brick de Guerre 24" starting from ANCRE plans; but when I go to my daughter's house what and how can I do? I decided that it's not practical to bring back and forth the Brick and related material: the more the build progresses, the more it becomes cumbersome and the materials and tools needed increase, so I thought a solution that allows me to do any activity in Tuscany without having to make use of the materials and equipments located in my lab at home.
The solution is for me the purchase of a kit: with this option I have everything I need (even though that's not completely true) in the kit and then I solve 90% of the problem for the materials while regarding the tools I can duplicate the equipment, on a minimum basis, or take them from home, not having, however, the need for great efforts for transport.
Of course, in the months where I'm in Cinisello I'll work on the Brick, and when I'm in Tuscany I'll work on the kit. This means that to finish the models I'll most probably need twice of the time, but I don't think to die in a short time (sign of the horns exposed more and more times) and, with regards of patience, I don't miss it.
I took advantage of a fairly advantageous offer from a Czech kit manufacturer, the Dusek Shipkits, http://www.dusekshipkits.com/, and I bought via the internet two Viking ships:
1) the Gokstad ship, found in Norway and
2) the Skuldelev 1, a knarr, transport ship, found along with other boats in Roskilde, Denmark.
Both kits are marketed in 1/72 and 1/35 scale. I chose the 1/35 scale. To start I decided to build the Gokstad ship.
I want to start with a minimum of history about this ship, on display in a museum located in Oslo.
The source is an article I found on wikipedia, from which I extracted some contents relating to this ship:
The Gokstad ship is a 9th-century Viking ship found in a burial mound at Gokstad in Sandar, Sandefjord, Vestfold, Norway. It is currently on display at the The Viking Ship Museum in Oslo, Norway.
The site where the boat was found, situated on arable land, had long been named Gokstadhaugen or Kongshaugen (from the Old Norse words kóngr meaning king and haugr meaning mound), although the relevance of its name had been discounted as folklore, as other sites in Norway bear similar names. In 1880, sons of the owner of Gokstad farm, having heard of the legends surrounding the site, uncovered the bow of a boat while digging in the still frozen ground. As word of the find got out, Nicolay Nicolaysen, then President of the Society for the Preservation of Ancient Norwegian Monuments, reached the site during February 1880. Having ascertained that the find was indeed that of an ancient artifact, he liaised for the digging to be stopped. Nicolaysen later returned and established that the mound still measured 50 metres by 43 metres, although its height had been diminished down to 5 metres by constant years of ploughing. With his team, he began excavating the mound from the side rather than from the top down, and on the second day of digging found the bow of the ship.
The Gokstad ship is clinker-built and constructed largely of oak. The ship was intended for warfare, trade, transportation of people and cargo. The ship is 23.80 metres (78.1 ft) long and 5.10 m (16.7 ft) wide. It is the largest in the Viking Ship Museum in Oslo. The ship was steered by a quarter rudder fastened to a large block of wood attached to the outside of the hull and supported by an extra stout rib. The block is known as the wart, and is fastened by osiers, knotted on the outside passed through both the rudder and wart to be firmly anchored in the ship.
There are 16 tapered planks per side. The garboard planks are near vertical where they attach to the keel. The garboard planks are narrow and remain only slightly wider to take the turn of the bilge. The topside planks are progressively wider. Each oak plank is slightly tapered in cross section to allow it to overlap about 30mm the plank above and below in normal clinker (lapstrake) style. Iron rivets are about 180 mm apart where the planks lie straight and about 125 mm apart where the planks turn.
At the bow, all of the planks taper to butt the stem. The stem is carved from a single curved oak log to form the cutwater and has one land for each plank. The inside of the stem is hollowed into a v shape so the inside of the rivets can be reached during construction or repair. Each of the crossbeams has a ledge cut about 25 mm wide and deep to take a removable section of decking. Sea chests were placed on top of the decking to use when rowing. Most likely on longer voyages sea chests were secured below decks to act as ballast when sailing. The centre section of the keel has little rocker and together with flat midships transverse section the hull shape is suited to medium to flat water sailing. When sailing downwind in strong winds and waves, directional control would be poor, so it is likely that some reefing system was used to reduce sail area. In such conditions the ship would take water aboard at an alarming rate if sailed at high speed.
The ship was built to carry 32 oarsmen, and the oar holes could be hatched down when the ship was under sail. It utilized a square sail of approximately 110 square metres (1,200 sq ft), which, it is estimated, could propel the ship to over 12 knots (22 km/h; 14 mph). The mast could be raised and lowered. While the ship was traveling in shallow water, the rudder could be raised very quickly by undoing the fastening. Dendrochronological dating suggests that the ship was built of timber that was felled around 890 AD. This period is the height of Norse expansion in Dublin, Ireland and York, England. The Gokstad ship was commissioned at the end of the 9th century during the reign of King Harald Fairhair. The ship could carry a crew of 40 men but could carry a maximum of 70. The ship's design has been demonstrated to be very seaworthy.
Both kits have the same price: in total I spent € 230, including VAT and shipment. A price (115€ each) quite interesting also if the kits are rather simple.
The completed model should look like in the images 01 and 02 here below.
Length: 610mm, Width: 260mm, Height: 370mm
y4mzT5opfa2RkwCtkVjQPookO7K257aep8myz3m5
y4mUzzoR_FozlqwxD2PmhHwFuctVZGwLSSnnjyVr
The kit of this model, shown in the photos 03 and 04, looks like this:
y4mDL2bS2QsYqdsUkvi87DhZkBVt3B22NLC6NaJU
y4mrNQJwRMDTZ4osvyyldluTUzBHzjZuc7upQPxG
Inside there is the materials, drawings and building instructions. On the internet there are also downloadable files with the same instructions at: http://www.dusekshipkits.com/viking-gokstad-1-35
That's all for now, but the adventure has just to begin . .
Cheers, Jack.Aubrey
And now let we open the box to start discovering its content . .
At first the model plans in 1:35 scale
: this is a single sheet. This fact is not surprising as a viking ship is not a three decker, but something much more simple. In the same photo the paper version of the assembly instructions.
01 P1100351.jpg.
y4mlqLLp7BK59kYmwLUCdn8ji60pdh--hGuAOvo1
Unfortunately (but it is not my case) for non english mothertongue, the instructions are written in English, but the online version are also in Czech, French and Spanish. At a shallow reading it seems clear and quite simple; if there are some inaccuracies they are not established at this time; it's probably necessary to start working before finding something wrong. Below some sample scanned pages to be taken as an example.
02 gokstad35-english_1414511927-3.jpg.
y4mantGtFe-Svw2ByXU53PlEqiQUSfE9KjCDmOB3
y4mO4_VOemdaspVqIfH89m3UZYnXCD6Krntkg_h6
y4mGdTHq2HJbSG1SmC5_9lWNv3nGZ3b38EU2BB3U
Finally, the actual content of the kit: laser pre-cut pieces of plywood and veneer of various thicknesses.
y4mfywSxq779keYJ2DTgdsyNylFDS0bGmJsy9jba
In the next post we will see more in detail these pieces.
Sincerely, Jack.Aubrey
Let's see the content of the kit item per item . .
in the box we find some pre laser cut plywood boards wrapped in plastic to protect them from "accidents" . .
y4moJprII0kSbM38rAk7PTjAMsbFY2MYYr4rZcQ4
Keel, frames or bulkheads, and a base for the pedestal . .
y4mjYfiwM-mDixf7GQ__9S6D7Vox3WlSQ-TDUS_W
Deck, various rods, probably to be used in building the tree and the several oars . . and, in the upper left, some smaller pieces, some of them made with metal, packed in plastic envelops. .
y4mv23lvzKfFvtSeuMh9epgMnonYNqdZH1ndh_16
The strakes . . as you can see they are not straight strips, but pre-cut pieces rather crooked . . meaning a design with a 3D CAD software. .
y4meA1IctpLpm5N0Q5hCK22nNAj0Sg5x1HKDo0qh
Other strakes, the round shields, that characterized these boats, and fine wood fittings for the deck . .
y4my9xPJCWo27p01I_k7XWaaB-4pyXxBxZEv2Dly
That's all for now, the kit presentation ends here . . . Now all what remains to do is to start building . . but you will have to wait for it until I'll come back in Tuscany (planned for mid December), here I work only on the "Brick de guerre de 24".
Sincerely, Jack.Aubrey.
Lucky you....traveling, visiting and Part-time living with Familie ..... and everywhere you can build models
Lucky you
But also we have luck - so we can follow more building logs - hope that you have everywhere internet connection
Sunday, January 3rd, 2016
It's now about fifteen days I settled in Tuscany, near Pisa, where the weather is much better than in Milan, especially in this winter, till now without rain and with pollution . .
During the Christmas and New Year time I thought about how to transform the garage, I rented this summer, in a shipmodeller workshop where spending some time with my preferred hobby, even when I stay here in Tuscany, quite far from my main workshop. As I previously wrote in this topic, not believing feasible to continue working on the "Brick de 24" when I'm away from Milan, I thought to build a Viking ship model starting from a kit. The "Brick de 24" is the model I'm currently building in Milan from scratch and described at ....
I have already presented the Viking ship kit earlier in this topic and now there is no need to write more. Instead, before I can start to seriously do something, I had to plan and get some simple "furniture" absolutely necessary to me for working:
1 - a usable worktable
2 - a couple of shelves,
3 - an upgrade of the existing lighting
4 - an electric radiator to heat a little the workshop when, during the cold days that will sooner or later come, it will be certainly needed, although the weather here is not like in Milan.
Easily archived steps no. 3 and 4, for solving the first two I planned a visit at the IKEA shop in Pisa, but later I changed my mind. So I went to a carpenter's shop and there I noticed that I could get the wood needed for scratchbuilding my furniture among pieces of debris cuts, offered highly discounted for sale, having anyway an very good quality. I then realized that buying a power screwdriver/drill/hammer and the wood I'll have spent the same money to buy what I needed at IKEA. But at the end I'll get also a drill . . tools missing here, and I would enjoy even for a few days great DIY sensations.
After purchasing the drill (it also sounds a great tool) the shelves were built in a short time. Then I started the worktable. The pieces were cut in measure at the carpenter's shop and I had only the job to mount, glue and screw the several elements. Below a couple of pictures of the worktable in two different states of construction. I believe to finish it definitely tomorrow installing a lower shelf.
y4mSNQS65XqhLVr2aCxtQLB_vEjAehSzeC5NUDTw
Below, the worktable with the final top shelf added and already used by one of my five assistants to test its features and functionality . .
y4mHtGXoHqeAY7hKBwHDNEjWCaQLRdGipz3GGEq_
Now I just have to better organize the layout of the garage and take out the materials and tools I brought from Milan. Then I'll can finally start the Viking ship.
Greetings to all and happy Epiphany. . Jack.
Tuesday, January 5, 2016
Everything is now ready for the inauguration !! The worktable is ready, the shelves as well. . the chair is temporary, too low, but soon another most suitable will come from Milan. However improvements can always be done provided they will be needed.
So I can finally say that I could start doing something serious from now.
I'm starting to study the drawings and the assembly instructions of this Viking ship. For the moment I have some concerns about the rigidity of the hull framing, I fear some kind of deformation. This will probably happen if I'll strictly follow the provided instructions. I think there is a strong need to think about a building slip useful for a capsized assembly that will allow me to work keeping held the hull until the installation of almost all the planks. But it is not so intuitive about how to do it !
I'll sleep on it ! Let's hope in a viable solution . .
The worktable finished . .
y4m0uOuDKZp5mysTbkGQfDGopOczsmSPSlQTwDqE
The two shelves side by side . .
y4mwEwGq5_Q2YivUAHfx9c6LWR-UL7rkXjBS1M1a
An overview of the workshop: worktable, shelves, radiator, water, lighting enpowered and desktop backup, only the chair is unsatisfactory.
y4mtuKWmT0XXctQVjjE04-sMYHw47VV9wlp6A3zX
Friday, January 8th, 2016
This day is important 'cause it's the offical starting date of this build.
I started by assemblying the first building slip I planned, the right side up one. The process is still on the way, 'cause I found a lot of tools and materials missing or unusable. For example I took with me from Milan a new pack of polyurethane glue I bought time ago, but I discovered it was mainly dry and so unusable. Then I found the need for a small hammer and other similar misfortune. Today I'll continue the same task hoping to finish it.
Rgds, Jack.
An interesting link to an old publication about the Gokstad ship:
https://drive.google.com/file/d/0B752g0VVxf2KOGNjOV9lelRiazQ/view?usp=sharing
And some additional links to other Viking and their ship publications. I think there is enough material to become experts about our ancient friends
https://drive.google.com/file/d/0B752g0VVxf2KMXh1MGZjRHNoZnc/view?usp=sharing
https://drive.google.com/file/d/0B752g0VVxf2KMDRGOTJVMWFtbWc/view?usp=sharing
https://drive.google.com/file/d/0B752g0VVxf2KcE1Eb1BOb0czbmc/view?usp=sharing
https://drive.google.com/file/d/0B752g0VVxf2KM1JrdWJicFpMZ0E/view?usp=sharing
Regards, Jack.
Sunday January 10th, 20216
Yesterday I completed the setup of the building slip specifically designed for the initial hull assembly . .
y4mcE81wk2xzn94EozDqgH08KXHJJu7YC04ZrfZm
. . and later I put together the keel, made with two shorter elements and two small reinforcements to apply over the junction.
y4mq0Xr-rGQXjY8mie9eaPgterG8KymypY6xCzPe
A tough of class (!) . . a nameplate (very artisanly made) with the name of the model.
y4mDNCnTv5AvE4h3RerTwAUWW3hoPciuyU4befrq
Cost of these materials: € 1.00 for the base in 18mm plywood, € 0.65 for the 5 x 10 strip and € 0.30 for a small plywood table of 4mm, the same width of the pre-cut keel provided with the kit.
to be continued . .
Cheers, Jack.
Further considerations about this building board . .
The keel of this model is very long and, with respect to its length, rather low. It is therefore quite flexible and can bend easily; and this isn't a good thing.
As I probably have already written, the main function this building board must perform is to keep perfectly straight and 90° perpendicular the keel. This goal is achieved through the strips of 5x10mm. fixed over the 18mm. plywood basement and on the two lateral, vertical sides. Once the keel is inserted into the grooves, it is held in its position straight and vertical, with no possibility to alter this state.
But there is another important feature in this keel: the lower part is not straight, as usually happens in the models of sailing ships that we are accustomed to build, but slightly arched, that's it tends to move up to the prow and poop, also presenting over its entire length a slightly curvilinear shape.
How to glue the two pieces, that make up the keel, with the correct sheer ? Simple, just assemble them over the sheer drawing. But then who guarantees me that the keel will not flex within the building board ?
And here come into the field the second function: make sure the building board prevents the keel to move in swing when a slightest pressure on it is applied. It is with this goal in mind that I have prepared two special curved elements, which perfectly follow the prow and poop curved lines and force their correct inclination.
The four images here below "visually" clarify this particular feature.
y4mFNeJsq2JeU9giWk5sB_ceU5HeFObAOplj8oUw
y4mOwqrr8BZybWlbFMwqCqcsUP9_EjvnESsMWvGT
y4mhL7XYhP-erwJ9SgG_glZw3yizvrwsARsb_faL
y4mHlTE3XQae1_fOgPKOKhB7Ynb1knBtXGgvgI5N
That's all till now, but there is still another aspect to be clarified: how can I install correctly the bulkheads ? That means they must fit perfectly vertical with respect to the two axes of the keel, the longitudinal and the vertical ? And how do I ensure that the frames are set perfectly parallel to the bottom of the building board so that the two sides of the hull are 100% symmetric ? I'll describe my solution in the next message.
Cheers, Jack.Aubrey
Treating the bulkheads and the keel
The Gokstad ship, and probably all the Viking ships, once completed, were "sealed" using the caulking process. In those days this was through tar and animals fur: goats, sheep or similar. Once filled the cracks, tar was spread throughout all the hull timbers to provide also some kind of protection against the weather elements. Hence the characteristic "quasi black" brown color of these boats.
To realise this model I therefore thought to stain the precut pieces before mounting and fix them. To stain I decided to use a walnut mordant, very very concentrated and dark. I've done this NOW, before to install, because if made after any glue residual would not allow a well done staining, especially so dark. But staining prior to bonding tends to melt with glue, so, to avoid this second problem, I also treated the stained pieces with one/two coats of vinyl glue diluted to 50% and immediately dried with a hair-drier. This trick avoids the occurrence of the problem just described. The same procedure was used for the keel and will be used for the planks. After the diluted glue, a light sanding to smooth the surface and spot the brown color.
Below is an example of some frames treated this way. Areas not dyed will be hidden after the installation of the deck and planks.
y4m0Ne_CZmoVzbOkjKkHkGz6p1SrN_zU880gSSgc
Frames positioning and installation . .
In the previous message I raised the issue of how to precisely mount the frames on the keel. The problem is to mount them 90° relative to the keel, 90° with respect to their vertical and parallel to the building board basement, that means perfectly horizontal.
To do this I prepared the instrument shown here below. On one side I signed a reference grid to help positioning horizontally the frames. Positioned and fixed in the right place on the building board, according to the lines drawn with a pencil on the same, this tool lets you mount and bond the frames rather precisely and stable until the glue hardens. After +/- ten minutes, it will be possible to switch to mount another frame and so on until the end.
And it's what I'll do in the next steps. Sincerely, Jack.
y4mWoDPN50QUOWlOwZ1ZBKve-cejsEXWA7bFrVFd
y4muqq688KTuI6AuEMW1EDq4K487zWoya5n_LHl3
y4mJpYm7ZkETJdBjD0YWHmeD5OpND49hUkafaT1d
y4m-xX31G77sUF1jgl662mgXAE_bTWLTyJPJkMOW
Clever and simple solution - these are the best jigs ever - very good with the horizontal lines - so you have it easily under control :cool:
Don't get me wrong, I admire elegance and have an appreciation of the finer things in life. But to me, beauty lies in simplicity. Mark Hyman
Tuesday, January 12th, 2016 . . Frames installation.
On the day that my daughter left Pisa for Los Angeles, where she will stay +/- for a full month, I started with "nostalgia" to install and fix a first batch of frames of my "Viking". Obviously I used the process I described previously and I must say that it works brilliant, at least until now.
Here in Tuscany my new workshop seems to run well: till now I didn't need to use the electric heater because the weather feels more spring-like than winter. Only one thing confirmed its uncomfortability and impracticability: the chair, but in ten days will be discarged.
y4muPkgBMSNnNpzx0Tcwu3-jBDyf31VeZCblOcf1
y4mGHJu7jVx7O8swbAF8mODIgQEtiUfsy16Kt0Yk
y4mXKT1dcLjCZKbIbcuAcahRA6e_SF8cqUzFF9hW
y4mlGdgFKca78jfpVW6o3hbrJ_cJueZcyFjTFcEm
Regards, Jack.Aubrey
Thursday, January 14th, 2016
Today was really a whole day with rain . . without any pause from morning until midnight. The small river close to me has nearly tripled its flow rate, although without absolutely no risk of flooding.
So nothing better than close myself in the lab and do something. Then I finished installing and fixing, using the usual system, all the remaining frames and spending the idle time waiting for the glue by reading "The Lord of the Rings", Tolkien's classic fantasy masterchief. The result can be watched in the attached pictures.
What remains now to be fixed are the last two frames, those at the extreme bow and stern that have a different development from the others, and then I have to stop and think about what to do next.
I tried to remove the hull from the building slip and immediately I got to see how it is flexible and very suitable to incidents. Therefore it becomes inevitable to adopt a new building board that will hold hardly and perfectly the hull in a capsized position. This is because I do not think it will be possible to apply the planks with the hull in a different position. In addition there is the problem of beveling many frames; fortunately this angle is not very pronounced, but only the simple action of smoothing one frame, without firmly holding it, is rather risky.
The current building slip will be again useful later, after planking will be complete, allowing to work on the deck and its superstructure.
Hence the need to think, and maybe for some time, on the next step: the building of this blessed new planking board. Of course I'll keep you informed as soon as there will be something new to show.
Sincerely, Jack.
y4mvdgsmMcPthQV57RampJZRQZsYw_0cCRT6YL7X
y4miSDIjPXamCY5Smy5tqwmCxOkgDXSBZmOgcH_W
y4mF-ZHNB9XU1HuOZ20UaDSmbOeaPbZT1adkSa1X
y4mSVTMPfEdYKG3HU84ALinzXFOfE7aHFz4cMsYJ
y4mk4kuv7ABhE5DcDc8rfx2POvbHgfXTc94x0gNG
Sunday, January 17th, 2016
- Preparations for the second building board -
A negative feature of this kit is the lack of some drawings that, at least in my case would be very useful. For example the drawings of all the individual pieces of plywood (keel, frames, etc) are missing. For this reason I have jealously kept, without altering it in any way, the plywood table where there were the laser precut pieces so that, if necessary, I can redesign them simply passing a very thin pencil tip inside.
During the preparation of the keel, provided in two separate parts to be joint, to make sure to fit them at the right angle, I had to build the first building board properly. But later I continued my work forgetting to draw on paper the resulting shape of the entire keel.
During the study phase for the second building board, I unfortunately had a need to detect the internal shape of the entire keel and, in absence of drawings from the kit and having lost the right time to get it when the piece was still traceable, I had to find a way to get this shape. I had two options, one of which was to obtain a complete picture of the keel on my computer in order to draw the piece to be cut out for the new building slip. If this system didn't work, I had an alternative but in practice I had no need to use it.
I basically redesigned the two pieces of the keel copying them from the plywood frame tablet, then I scanned them with my computer and imported the files into AutoCAD. From there I started to work on their match. The result is the design reproduced below (bow at right and stern at the left) that, I saw later, proved perfect in all points . . computer power . .
y4m5Dx9lCK71qpwwmaLxkDS4irkNwfcjARvjqyM_
From this drawing I could then derive the key element I need to build the new building board, board to be used for the installation of the planking. Monday afternoon I cut the first pieces of the board and today I will proceed further.
Stay tuned. Regards, Jack.
Monday, January 18th, 2016
I started to assembly the basic elements of the new building board . .
The first element is the usual poplar plywood table of suitable thickness (18mm) that will become the board base. In the following image a preview of how the skeleton, overturned, will show once the building board will be completed . .
y4m6qU2GFqsXP4vnrm0kjRXA-vbApWtTDwVnm14H
The famous component that reproduces the internal shape of the keel, made in plywood obviously of the same thickness of the keel of the model: 4mm . .
y4mlvupR_ocXz5Rpuvjl42y383FSuuIFlGPDRTVa
The lower part of the base, where I added two elements to keep the basement raised, allowing the bow and poop tips to stick out without protruding from the base, avoiding to touch the working table.
y4m2lh8dtUITEIUsFucFUqX_ma25RlQHl8MIC53A
The element shown in picture 02 mounted on the basement, perfectly perpendicular to it, while the glue is drying. .
y4mqWlxZBbmhIwDjV7XwEmtpnuei5e_h1llIjcwY
Thursday, January 21st, 2016
Second building board completed . .
Finally, after a couple of days that I could not stay working in my workshop due to a cold weather, yesterday I found the right conditions and I finished setting up the building board, board that will be exclusively used to apply the planking.
As you can see from the pictures below, with this building slip the keel and frames assembly is rigidly fixed to it so that all the pieces are firmly stuck in the (hopefully) correct position and unable to move. I believe that with this method it should not be difficult to avoid any kind of deformation on the three main axis of the model.
Starting from now I can proceed with the planking, obviously after beveling where necessary.
Now comes into play the quality of the kit builder project. My aim was to put the pieces so far mounted in the best position to apply strakes, which, as you can see the first images back in this topic, are already pre-cut to the correct shape, as they are not the usual straight strips. If the Dusek kit project will be good, then it should be a simple walk (just to say), otherwise. .
Also for the planking there is the problem to dye the wood before its application, as for the keel and frames. We will see how to proceed along the way.
Now, however, I expect a few days of other commitments and probably I will produce few interesting thing for a while. Here follow a batch of images showing this new building board in detail. I hope its architecture sounds clear. If in doubt, just ask to me.
Regards, Jack.Aubrey.
y4m3p5BYcCVMvbCve03Haf8toRe3kHUSY5MCmn1f
y4muRYDRk96zSRlQQGcZN85a0j9SFCDfYTMQBjKN
y4mtinyeRzssZwkXwzF8Zt87ZPb8Fyc3Bcg8WTcX
y4mzVsRg9NawrIdGxcqCdxOK3iUdee-nayLUst5W
y4mAp55-Nit4VQ-tjaILutZNqOR7EYZGpeFmHdg7
y4mejpYrd-WscIlJbXDhT0RIXuCpnhI4LFgKdzTu
y4mo5lDAlbcNoTNaKJ8by61rmaSIOsJv8TxYOazI
With the goal to make more iteresting the topic, I quote here a comment from a user asking me why I didn't follow the kit instructions to build this model . .
Here is a thing I don't understand: the building instructions as you showed them, tel you to first attach the deck to the frames before you start planking. This would immensly strengthen the frames. Why do you go into plakning before installing the deck?
Jan
My answer . .
Jan, you are right: the building instructions tell us to fix the deck to the frames before planking. As you say this will stregthen the structure. But, this strength is only applied on one axis and in my opinion, for this model this is not enough . .
I try to explain better: considering the relative small height of this keel, also with the deck installed you probably may not assure the required rigidity of this assembly. In fact this is not probably enough to ensure avoidance of torsion movements of the hull and keep held the prow and the poop.
So, all my infrastrucure is finalized to avoid any kind of torsion of the hull over its three axis. The deck can be installed after the planking when the hull will be detached from the board. In addition this method allows me to enforce the internal side of the hull below the deck if necessary.
Keep in mind this is my first experience with clinker planking and I'm trying to achieve the best result with minimal risk . . think for example to the process of beveling the frames: with my method you can sand the frames without major risks to broke them because they are firmly locked and consequently, more safe.
To conclude, always remember the mission of a building slip: keep the hull structure in the perfect shape until planking is sufficiently strong to avoid distorsions. You may avoid to use it only in few circumstances and, believe me, this is not my case . .
Cheers, Jack.
Friday, January 29th, 2016
In the last days, I proceeded to apply planking with the famous method called "clinker": I was a little worried, however, so far, it has been going pretty well.
The pre-cut strips, already shaped, until now worked in an excellent way. The only flaw is that each strake is composed of two strips, one long and another shorter. And this fact required a joint and only after some time I finally realized that the shorter strip had exactly the same shape as the initial part of the long one and then I could put alternately forward and aft as desired with, in my opinion, a better result.
The poop is smoothly evolving, except for some points to be finished after the stern wheel, while the bow is much more tricky: its evolution is different than that of the stern and the strips must be forced a bit more to follow the water lines.
According to me the prow strips had to have a different shape for this zone, not equal to that of the stern. But for now that's fine too.
After have installed a pair of strakes I should be able to detach the model, it should not move anymore, from the board so I'll can install inside the deck and then proceed with the sides with the hull upside right.
However I need to proceed quite slowly, maximum a few strakes per side each day . . but it is better than I thought.
Regards, Jack.
y4mo-ps4DlNXMuwpSRvUu7H2m3_1aFub0APpIGuB
y4mnXYvIcNjhekG3-JulBZFt1os_EmrBNkWzZ9aH
y4myqx6SlxH744U0A__7T8qwOX4cYEs5XJYRu0NM
y4mKpXzhyXijRDyGpyaGUM7jpW4QvteYTUdQLDXl
