After all the excitement of
@Pathfinder65 Jan's great detective work this morning, it was time to to make the most of my day off.
That meant that it was all about planking the bottom and then some. The actual bottom planking is done in Pear Wood and consists of 6 pre-cut planks while the two end pieces are planked with diagonal strips of Pear Wood (also pre-cut). Unfortunately, I neglected to take pictures of that, (I have far more important pictures to share with you
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) so I have to rely on the photographs from the instruction manual. You will see now what I mean by the “grainy” quality of the instruction manual pictures.
Here you can see the the six pre-cut pieces of Pear wood that will make up the bottom planking.
Note the two sections of 5 shorter planks that will make up the planking for the two end pieces at the bow and stern respectively. These will be planked diagonally.
The planking process itself was very straightforward. The pre-cut planks were a perfect fit and because the area to be planked was smooth and flat, it went quickly. The same applied to the diagonal pieces on the two ends. All in all – eazy-peazy!
The bottom planking completed. The big, red tick means that my planking looks exactly this (for now you will have to trust me!
So now the time has come for planking the hull, This was where I screwed up big-time with my first build and which was the reason why the model was relegated to a dustbin. Now let me say that since then, I really enjoy planking. I am confident with it and have had very good results, but this was different. Let me explain the challenge.
Bear in mind that 90% of the four plywood bulkheads (marked with red arrows) will be removed – thus I could not use them to glue the hull planking to. Also bear in mind that the top halves of Bulkheads #5 and #6 (50% of their total area) - marked with green arrows - are also to be removed – thus no glue! This means that for the entire centre section of the hull (the section in the blue block), the planking would be unsupported.
And then the clincher! The pear wood planking strips are 2mm thick while the bulkheads are only 1.5mm thick! Don’t get me wrong … I love the idea of the extremely solid and high-quality planking strips, but how … oh how does Unicorn envisage one to plank them on paper-thin bulkheads of which you can only use half?
But ... if you think long and hard enough, drink coffee and smoke enough Yuxi (my Chinese brand) cigarettes, you may just find a potential solution. Remember, this is my second build and I was fully prepared this time.
The "solution" (at this stage I don't know if it is a solution yet or just vain hope)? A message to
@yqmodel Xiuli of YuanQing saw five 11mm x 11mm strips of Pauwlina wood (the Chinese equivalent of Balsa) delivered to me FREE OF CHARGE! Thanks, Xiuli! Then it was a case of meticulously shaping each piece to the exact size and inserting them into every conceivable nook and cranny that I could find.
Plank on Bulkhead construction? To me it looked more like a “Bread and Butter” build! (The hammer and Chinese glue) are vital parts of any build of mine.
Then it was a case of gluing the filler pieces into the deadwood areas at the bow and the stern, shaping them to size, and now the hull planking could begin! Wish me luck!
Until next time, take care, stay safe and happy modeling!
Warmest regards - Heinrich
