So I pulled out all the deck rails and replaced them all with a better piece of pearwood, so now it all matches the ribs. I had a spare piece left over from planning that was the correct width so it worked out.
Test fitting the upper deck and everything seems to fit well. When I put in the new lower deck rails I took the opportunity to realign their placement with the gunports. So now they should fit more accurately and sit just below.
Next I started on the carlings.
If you notice the right carling is at a slight angle then you noticed before I did.
It's now on the left but it's a slight angle. No way to fix that, I'll just have to deck over it if it bothers me later. In the meantime I did install the first three deck pieces, and it'll be a process working back towards the stern. I feel like I should probably glue these pieces in as a go in order to make sure they fit snuggly in the end.
