- Oct 1, 2023
The eagle has landed. Got the kit this afternoon. Thank you RegView attachment 428382
I will. And thank you for your assistance in me getting this kit. I just had a first look at the plans and materials. Absolutely phenomenal.Great stuff, Ted - I am really excited for you. When you start the build, please make sure to post your build in the Bluenose Group Build section https://shipsofscale.com/sosforums/forums/bluenose-pof-group-build.319/
Simply scroll to Bluenose Group Build Logs and join the family!
I moved this thread to the group build,Ted can continue and start the build log hereGreat stuff, Ted - I am really excited for you. When you start the build, please make sure to post your build in the Bluenose Group Build section https://shipsofscale.com/sosforums/forums/bluenose-pof-group-build.319/
Thank you, Zoly.I moved this thread to the group build,Ted can continue and start the build log here
Thank you, I'm forcing myself to finish my current project, the Virginia Swift, before starting the Bluenose. I just have a couple of gaffs and rigging to go. Really basic on this model.Thank you, Zoly.
Great to see the start of your Bluenose build-log. I will ad it to the BN-list.The eagle has landed. Got the kit this afternoon. Thank you RegView attachment 428382
It’s good to follow another builder. Here’s Paul build-log with also his video’s and some other information in between:I've been following Paul Lester's Bluenose build on YouTube. He is using cut down melamine blocks to clamp the hull frames during glueing. I'm building off the top of an old kitchen table. I can't afford to go out and purchase plates of glass just to glue the keel. Would lining the table top with wax paper or plastic wrap be sufficient without causing me problems later.
Hello Ted, Welcome aboard the great YQ-Bluenose build Form, You will find lots of yelp here on the SOS Bluenose Form. May I suggest that you go to your local glass store and ask for some of there old used glass, this they will gladly give it to you for free.I've been following Paul Lester's Bluenose build on YouTube. He is using cut down melamine blocks to clamp the hull frames during glueing. I'm building off the top of an old kitchen table. I can't afford to go out and purchase plates of glass just to glue the keel. Would lining the table top with wax paper or plastic wrap be sufficient without causing me problems later.
Thanks wilcoHello Ted, Welcome aboard the great YQ-Bluenose build Form, You will find lots of yelp here on the SOS Bluenose Form. May I suggest that you go to your local glass store and ask for some of there old used glass, this they will gladly give it to you for free.
Regards Lawrence
Thank youHi Ted. Great to have you in our group. I will be looking forward to seeing your build.
That's an excellent idea. I'm going to call a local glass shop today for used glass. If that doesn't work I'll go to Walmart or AmazonFor building the keel and frames, I suggest that you might check Walmart or Hobby Lobby for some medium size photo frames for affordable cost, and use the glass from them, but be careful as it is usually thinner glass than what a glass shop would sell you.
