- Mar 22, 2024
If these work ok on hard materials like walnut veneer I could see one being useful to me. Does anybody have an opinion to share on this tool?
Hi, what do you do after a few dozens of cuts the area under the blade becomes dented by razor?I have a razor chopper from Micro-Mark
Sadly they have none in stock- but it does look like a better proposition than the Amati one. Thank you.I have a razor chopper from Micro-Mark
I agree with Krister. I have one of these Amati cutter and don't like it. One of the drawback I see is the lack of precision in terms of angle.I have one, but I don't really like it. It's plastic, doesn't feel sturdy and it's difficult to get a precise angle. I've tried to cut a strip of birch, ca: 7x1,5mm and I'm afraid I'll break it if I press hard enough to cut through. Walnut is of course a bit softer but .........
Maybe you can show us your new / old tool with a photo? Sounds interestingI found the answer to my problem. A vintage Emgee brand all-metal paper guillotine, probably 50 years old, but clean and obviously spent most of it's life in storage as it is razor-sharp. Cuts pear, holly, and hornbeam veneer both along and across the grain perfectly down to around 1,5mm wide cross-grain and 1 mm along the grain. Cost me around $ 30 on Ebay. I need to devise a length-stop, but that should be relatively simple.
You can easily add a photo in your post via the button "Attach Files" at the bootom left side when you write a post.Happy to do so, just need to work out how.
We used to have them in primary school for cutting paper sheets. I’m 68 now. Laugh!This is virtually a clone of the one I have. You get the idea, and btq thank you for pointing out the 'attach files' boc.
DSPIAE is a high-quality tool among other Chinese brand names. I own some of their tools and can confirm.I just spotted this chopper on Aliexpress. Not sure if it's any good, but it's certainly cheap/
