I've started on the planking. The kit is a double planked model and the OcCre instructions indicate a black brush painted hull. I had good luck with the Niagara using Krylon spray paint and I really liked the look, so I am going with that as my goal. We'll see as I get closer to that stage.
For now, I am proceeding with the the 2 mm x 5 mm provided wood strips. 2 mm seems a bit thick to me, but I'm sure I can sand down as needed. The instructions indicate using nails hammered all the way to the surface after applying glue to the strips. I have found on some other logs that having to file all of those nail heads flush after the glue has set is a little excessive. So I am trying a suggestion to use nails to keep the strips in place until the glue sets but not driving the heads all the way to the surface. Then when glue has set, I am pulling the nails out. The nail pusher I bought from Micro Mart is very good for this; not only to drive the nail in as far as you want, but also is very good in pulling the nail out later.
Here I have soaked the planks for about 2 hours, then temporarily set them on the frames. Nails are driven to hold the piece in place, and once the piece has dried in place, then nails are removed and the plank is removed to apply glue and attach to the frame.
Planks have been installed back on the frames and glued (I am trying WeldBond PVA suggested in a log). Nails are inserted only to keep in place, then using the nail pusher, I remove them leaving a nice clean nail hole. No filing needed on the heads when I come back later to lay on the exterior veneer strips.
