ZHL Misticque
Peglegreg
Well-Known Member
Moderator
Central Coast NSW
#82
G'day John
Here are some more translations:
9. Paste the intermediate branches of the D22 frames. So that the branches do not break, moisten them with water.
D32 D33 D31 10. Glue the parts shown in the figure.
A57 M54 M55 E56 A52 A53 13. M54 steering hinges are made from brass strip, M55 axis from brass nail or wire.
A48 D47 M51 A50 D47L A49 12. If desired, paint A47 plates with a black matte mask before installing them on the model. Mast repetition M51 is made of brass strip.
F59 SCROLL F59 F58 14. Model can be supplemented with oars. Also on the boat you can put sailing equipment, this will help you drawing and mast blanks on the plate G.
BOAT 6 - TI FUN 1763g. FEATURES OF THE KIT Laser nesting: flys and plating Details from solid wood and veneer rpy sheaths For patroyra r lotu aro8th photo tool quiet and drawing Fig. Rouoro. present www.falkonet.ru Length 100mm apt, F01s4
More to come
Happymodeling
Greg
#83
Hi all
Re keel clamp update.
This is for anyone that may be thinking of purchasing one.
The end keel holder has to have two parts glued on the bottom ( not to the top like I have done see RED arrows ) this is to make that part slide over the top of the keel support holder see GREEN arrow and line.
The part with the RED oblong round it, this comes in three parts two long ones out side one small one inside see ORANGE part.
You have to glue the two outside ones to the orange part that goes on the inside at one end, make sure you put a 9mm part or a scrap of wood at the other end to act as a spacer, glue the three parts together when dry take the spacer out ( I used one of the keel supports see YELLOW arrow ).
I did not use a spacer for the one above it you can see the difference when you look at it ( what is that saying dry fit then glue, what an idiot I am haha).
John.
#85
Hi all
Re new keel clamp.
I am starting my Misticque build again.
So I thought I would try the clamp out.
I found out that the two bottom clamps (one each side) that hold the keel inline did not allow the keel to drop down to the baseboard, this is not the fault of the keel clamp but the way the ships keel is held together.
The ships keel has to be glued together with two bits of ply each side they stop the keel from dropping down to the baseboard, if I had the keel clamp before I started the the build I would have cut 10mm off the ply wood so this would allow the keel to drop down to the baseboard.
Saying that I am very happy with the keel clamp.
Sorry the last two photos are in the wrong order.
This should be at the top.
