Triton Poseidon Cross Section POF Scale 1:48
Aussie048
Active Member
Melbourne Australia
#21
Thank you John for the following information on the Triton Cross Section.
Scale 1/48
Length 220 mm 8.6"
Width 125 mm 5"
Height 180 mm 7"
This cross section is product which being developed by HMS Triton, this derivative products use same processing methods and accessories line with Full rib HMS Triton
Take the first using CNC to introduce the design of the plate without connection point, the design of the rib alignment hole, the design of the transverse rib slot and so on
FUll ribs
American red cherries are used for keels, ribs cross beam and stringer
The artillery carriage , fence, stair and other individual parts using black walnut
The ship building berth use Australia pine boards which flat and solid
Artillery as a whole, casting fireworks, the outside has done and dont need do any thing
Provide solid wood base and support
PE included
A0 DRAWING
neptune
Well-Known Member
Australia.
#22
Its looking great Geoff, and you seem to be enjoying build it, and thats the main thing, I am expecting my Pillar Drill to arrive any day now, I will post some pics when I get it, got your email OK,
best regards John.
JosephH
Active Member
#23
looks good geoff hope the frames are more accurate than the drawings I got from another site
Aussie048
Active Member
Melbourne Australia
#24
Hi Joe
I guess that in the old days which are well before computers and CAD, seen the plans where drawn that a plan would have inaccuracies in it.
With my Triton Cross Section there are no plans as scale 1:1 to the model.
That will make it a bit more of a challenge, but we will get there.
Cheers
Geoff
Aussie048
Active Member
Melbourne Australia
#26
I was looking through the parts for the Triton Cross Section and decided to pull out a cannon barrel to have a look.
Yes I did have issues with shadows, but the cannon barrel I am more than happy with as the rest of the parts in the kit.
Cheers
Donnie
Well-Known Member
Madison, MS
#28
Hi Geoff,
just now sitting down just for a min and catching up on some more build logs. This is really a nice kit and I am sure you make well with it.
Donnie
Aussie048
Active Member
Melbourne Australia
#29
Thanks Donnie
I bought the kit because I wanted to learn POF.
I am learning, slowly
That became about helping one of our very good members watching his posts and helping him out
Cheers
Geoff
Aussie048
Active Member
Melbourne Australia
#32
I managed to make start sanding again today. I was using my pensander running around the inside.
It was short lived as I was not happy with one of the joins so I got my Isocol out and wrapped some cotton wool around the piece that need separating and drenched it with Isocol. This will losen the PVA glue. It will probably take over half an hour due to the thickness of the timber.
Cheers
Aussie048
Active Member
Melbourne Australia
#35
I started sanding and about the best I could come up with to use was my Dremel mounted on the drill stand. I never thought I would ever used the drill stand ever again but as I am only using slight pressure and the Drill stand is sitting at one height it actual works well.
I have only completed the left hand sis of the frame at this stage P1010103D.jpg
Aussie048
Active Member
Melbourne Australia
#36
Sanding and even more sanding.
I used the Dremel for the curves but for the flat edges used 180 grit. I have 2 more to get to this stage
Then I will move on then with a finer grit paper.
Cheers
Aussie048
Active Member
Melbourne Australia
#37
Today I sanded down the last 2 frames and set them in the jig. The still need to be sanded with a finer sandpaper grit or as I was told today use Wet and Dry it is better.
I will pick up some wet and dry tomorrow.
The frames now fit snugly into the jig. I gave to align the keel notch yet and make sure the frames are at 90 degree to the keel.
Cheers
Aussie048
Active Member
Melbourne Australia
#40
Hi Bill and John
Thanks for visiting my build log.
The plank on fame is a new learning curb for me.
It did pay to take it apart so it could be joined more neatly
Cheers
Geoff
