Sovereign of the Seas (Mantua) by Nj0rdr
DenisR
Active Member
#21
Hi NjOrdr
You still have to fit the block under the lantern at the stern end or it will be to low to fit the coat of armes under the bottom of the lantern (see the photo what I posted).
Denis.
Austria
#23
Finally some small progress again. There was a lot of work in the garden to do and also the job kept me busy.
At the moment I try to figure out how to place LEDs in the 4 lanterns on the roof of the balconies. My problem is that the LEDs are bigger than the opening of the lanterns in the bottom. Probably I will make a cut out there. And of course I also have to isolate the wiring to prevent a short circuit.
I will keep you updated.
Pat71
Active Member
#24
Great ship . Its on my wishlist. Gonna follow this one! Working onze my almost finished victory and the trinidad and the wilhelm zu pferde.
dj56
Active Member
#25
here another SOS member who will follow your work with a lot of interest
Greetings
dj56 (willy)
Uwek
Well-Known Member
Moderator
Vienna, Austria
#26
Although the additional work you made a good progress with your hull, which is looking good......unfortunately I did personally never LEDs in a model, so I cross the fingers, that you will solve the problem and find a way......but there are some specialists here in the forum......
Peglegreg
Well-Known Member
Moderator
Central Coast NSW
#27
G'day Nj0rdr
I think I might have a solution for you.
I bought on Ebay a set of 20 micro ORANGE LEDs for about Au$3.
It's hard to tell the exact size by this photo, but it is slightly bigger than a pin head.
The very thin wires are coated with varnish so they are insulated from each other. These wires should be small enough to go through a 0.6 mm hole.
But be very careful not to scratch the varnish.
It's very important to add 1 transistors at the positive side of each LED that you are using. If you are doing the lights in a series than you will only need one transistor.
This transistor can run up to 20 LEDs lights with the power supply.
It will be ok if you run 3 or 4 LEDs from this same power supply, but to be safe, do a test with the spare LEDs and run the test for a few days. I don't believe there will be any problems, but I also say, it best to be safe and be shaw, than sorry.:(
After you connect the lanterns with the LEDs inside, and if by any chance they don't work, swap the poles on the LED around until they all work. This is a trial and error because you will have to cut the LEDs of the series chain to do your lanterns.
Hope that you can understand what I'm trying to convey to you.
Happymodeling
Greg
Austria
#28
Hi,
thanks for the hint.
I have found a different solution: just make the opening big enough for my LEDs and I put on the blank parts a shrinking foil.
Additionally I have a small update. The 1st planking is finished. the next step for me to put on filler and start the 2nd planking. IMG_6223.jpg
Austria
#29
Hello all,
I would need an advice from you guys. It is regarding the gunport frames.
According to the instruction you have a frame part which you add on the outer planking. So there will be no smooth outer hull.
As far as I know the gunport frames are a little bit recessed into the hull. I have tried to do something like that with the leftover wood from the first planking. How far should the frame be seen on the inner side? See attached pictures.
What is the correct way of the gunport frames?
Uwek
Well-Known Member
Moderator
Vienna, Austria
#31
I don't know what I did but you can see what I did on page 2 & 3 of my model.
I was searching for the log of Gary and a post where you can see the gunports closer. Take a look f.e. here:
https://www.shipsofscale.com/sosfor...rgals-sovereign-of-seas.704/page-3#post-12712
I hope it is helping.
......and I recognized, that the gunports at Gary´s model have bigger openings, if we take the width of the planks on Gary´s and your model the same and also the diameter of the guns......
I borrowed a photo from Gary
Here the gunport has a height of 2,5 or even 3 plank widths, and at your model it is appr. 2 plank widths
and also the gun has no real space inside the gunport for moving or rebound of the gun
#32
HI NjOrdr, I did the gunports as a trial from scratch. The frame is made of 1mm wood strip and they are fitted inside the cannon port 2mm deep so that the window will properly close. see the photos
#33
Another photo of my test with the cannon ports you can see that two of the cannons are made of wood and the one on the right is brass.
Austria
#34
Thank you all for the great input.
The size of the gunport is obviously to small. At the moment the frame is made out of 2mm planks (just had some scrap lying around on the table). I will do another test with 1mm thick wood and I also have pieces with 0,5mm. Hopefully I can manage to try that today.
Austria
#35
Quick update:
I used left over parts from the deck planking of my previous build to make the gunport frame and I like the look of it.
On the pictures you also see the other version with the 2mm wood, whcih is too thick.
The picture from the top shows that the thickness of the wall is only 2mm. So I think I will add an additional layer of 2mm planks and finish with a 1mm walnut. This means an overall thickness of 6mm which is fine for me.
I also added a picture with the lid closed to show what I meant with smooth transition from lid to the outer planking. In comparison I also added the fram for better comparison and I like the version with the scratch frame much more.
What are your opinions?
Uwek
Well-Known Member
Moderator
Vienna, Austria
#36
Quick update:
My compliment for your improvement and your way to make the model technically more accurate. Therefore I have to say, that your scratch version is much better!
This is one example, which shows the additional benefit to have friends with whom you can share your work.....Great
Pat71
Active Member
#37
That looks great! Maybe i will try that on my trinidad. A part of the wood from the kit is not straight or has some litle bumps in it so i need tot use better quality wood at some points
Pat71
Active Member
#39
I would do frame on inside. Going to make them for my Trinidad too. Hope They send me the 35 missing Cannon ports and lids That come short in the kit.
