Schooner Halcon 1840 1:100
zoly99sask
Well-Known Member
Administrative
Moderator
Blandford Group Build
#7
Vladimir,maybe you glued those bulwark panes too low.
Uwek
Well-Known Member
Moderator
Vienna, Austria
#8
The lower edge of the gunport are definitely higher than the deck planking, I think it is also visible at the drawing of the kit.
These flat deck sloops had usually no gun-port lids, and the guns were also usually fixed running out through the gunport, so they had more space on deck behind the carriages.
They had no lids, so that in heavy weather the water can go out directly trough the gunports, in heavy weather the scuppers are not enough.
I have a very good example from the frigate Hermione, showing the real ship in slightly heavy weather, than this is understandable.
#9
Thank you so much!
Tons of useful information! I took off the plank without damage and going to correct it this night. I should be more attentive to the drawings.
I'm not so proficient in Russian marine terminology, furthermore, it's come mostly from Holland by Peter First.
But I'm studying while I'm doing. That's why I start the block and great thanks for you all!
I got this adds by mail for my Halcon. Cannons are amazing! 20181107_171324.jpg
Jimsky
Well-Known Member
Brooklyn, New York USA
#12
