Santa Maria - Mantua - scale 1:50 modified kit semi scratch and diorama
Canoe21 said:
Hello Zoltan
Golly that sure looks like a very nice kit, lots of very fine details and extra goodies. Did you buy that stern gallery casting or was it part of your kit. I just joined up on the M S B Form and was a bit surprised to find you here. Still looking for a set of build plans for the Spanish Galleon the San Francisco II , seam to be very hard to find, ENJOY.
Regards Lawrence
Hello Lawrence ,I am happy to see you here too,I will try to do a search for you on the San Francisco plans,but I seen you might look into the Santa Maria plans,I can help you with that.
Regards,Zoltan
Hello Zoltan
Yes it's always nice to look around at the other side of the fence, seams like a very nice build Form. As for the Santa Maria I will hold off for a bit longer and search for the San Francisco II, still have a bit of home work to catch up on before I can start a new build. I do thank you very much for your help,
ENJOY.
Regards Lawrence
The castings are part of the kit but I am not going to use them , they are not the best quality.
Hello everyone, thanks to everybody for visiting my build and for the nice comments.I finished the futtock riders on the port side, it doesn't look a lot but they were a lot of work.
Futtock riders port side (3) (800x600).jpgFuttock riders port side 02 [800x600] (Copy).jpgFuttock riders port side (2) (600x800).jpgFuttock riders port side (4) (Copy).jpgFuttock riders port side (5) (Copy).jpgFuttock riders port side (9) (800x359).jpgFuttock riders port side (10) (Copy).jpg
Hello Zolton
Great job you have did on your Futtock Riders the sure do look great and well done. I see that you cut your own, were they not supplied in your kit? Just wondering or just being nosy, ENJOY.
Regards Lawrence
Thanks Gary,yes it was a slow process to get the measurments right (26 futtock riders)and also to shape them to fit nicely.
Hello Lawrence ,thanks for visting my log again ,the instruction manual suggesting for futtock riders 5mm wide walnut strips in two layers,but I didn't like that idea.
Hello Zoltan
I would have thought that your kit would have laser cut out these Futtock Riders but to be truthful your scratch Futtock Riders are much better and fit so much better than those that could be supplied in a kit.
I have ordered a set of Harold Underhill's Plans on an Elizabethan Gallant as I could not find a set of plans foe the San Francisco II Just got word that they have to print this set of plans and that will take around 10 days, so in the mean time I am searching the web for ideas on how to build a display case for my HMS Bounty. I do believe that I have most of it figured out and with any luck at all I will soon be making saw dust, ENJOY.
Regards Lawrence
Hello Zoltan
Well done on your added Capstal it sure seams to fit in very well. You are much like I am by adding more detail to your builds, I think it dreses thim up just a bit and makes them more ineresting to look at and also a little bit special, ENJOY.
Regards Lawrence
I am working on the inner bulwark, glued in the waterway on the main deck and also drilled out some scuppers along with the holes for the anchor cables,and drilled the gun ports and dry fitted the gun carriages.
Main deck waterway and scuppers_000 (800x600).jpgMain deck inner bulwark planks (3)_000 (800x600).jpgMain deck inner bulwark planks (5)_000 (800x600).jpgMain deck inner bulwark planks (7)_000 (800x600).jpgMain deck inner bulwark planks (9)_000 (800x450).jpgMain deck inner bulwark planks (10)_000 (800x600).jpgMain deck inner bulwark planks (11)_000 (800x600).jpgMain deck inner bulwark planks_000 (800x450).jpgScuppers (2) (Copy).jpgHoles for the anchor cable (1) (Copy).jpgHoles for the anchor cable (2) (Copy).jpgGun ports with cannon dry fit (2) (Copy).jpgGun ports with cannon dry fit (Copy) (Copy).jpg
Brian077 said:
I'm just catching up on this build log, and this is a great looking model. Wonderful work so far my friend.
Thank you Brian for visiting my build log and for encouraging comment.
Hi Zoltan, you are doing a great job with Santa Maria. I am getting inspired for my SM :)
Thanks guys for the comments and visiting my build log,I will have some updates this weekend.
