Pinta 1492 by Mike 41 – 1:32 scale Caravel
It is hard to find good Minions in Kansas the best ones are found along the coast.
Poop Deck Framing:
This is a few photos showing the poop framing.
IMG_2847.jpgIMG_2837.jpgIMG_2838.jpgIMG_2839.jpgIMG_2840.jpgIMG_2841.jpgIMG_2842.jpgIMG_2843.jpgIMG_2844.jpgIMG_2845.jpgIMG_2846.jpg
Stern Planking:
The stern planking is basswood. This is a few photos showing the planking.
IMG_2853.jpgIMG_2848.jpgIMG_2849.jpgIMG_2850.jpgIMG_2851.jpgIMG_2852.jpgIMG_2857.jpgIMG_2854.jpgIMG_2855.jpgIMG_2856.jpg
Hull Planking:
The planking is basswood. These pictures show the advantage of using a swivel vice during the application of the planks by always working on a flat surface.
IMG_2860.jpgIMG_2858.jpgIMG_2859.jpgIMG_2864.jpgIMG_2861.jpgIMG_2862.jpgIMG_2863.jpgIMG_2865.jpgIMG_2877.jpgIMG_2866.jpgIMG_2867.jpgIMG_2868.jpgIMG_2869.jpgIMG_2870.jpgIMG_2871.jpgIMG_2872.jpgIMG_2873.jpgIMG_2874.jpgIMG_2875.jpgIMG_2876.jpg
Hull Planking (continued):
This is more progress photos of the planking.
IMG_2880.jpgIMG_2878.jpgIMG_2879.jpgIMG_2882.jpgIMG_2881.jpgIMG_2890.jpgIMG_2883.jpgIMG_2884.jpgIMG_2885.jpgIMG_2886.jpgIMG_2887.jpgIMG_2888.jpgIMG_2889.jpg
Forecastle Framing and Planking:
This set of photos shows some good details on how the foremast and bowsprit penetrate the deck planking. The model is back in the jig for this process.
IMG_2900.jpgIMG_2894.jpgIMG_2895.jpgIMG_2896.jpgIMG_2897.jpgIMG_2898.jpgIMG_2899.jpgIMG_2905.jpgIMG_2901.jpgIMG_2902.jpgIMG_2903.jpgIMG_2904.jpg
Good Morning Geoff,
One more set of photos and I am done for the day.
Gunwales:
The gunwales are made from walnut and installed with rubber bands and clamps in the jig. This set of photos shows the installation and finished gunwales.
IMG_2910.jpgIMG_2906.jpgIMG_2907.jpgIMG_2908.jpgIMG_2909.jpgIMG_2917.jpgIMG_2911.jpgIMG_2912.jpgIMG_2913.jpgIMG_2914.jpgIMG_2915.jpgIMG_2916.jpg
Mike
Excellent work.
Educational to any model ship builder.
Thank you
Cheers
Geoff
Gunwales (Note):
I used my trusty tea kettle to make the bends in the walnut gunwales. The old methods still work well and are enjoyable to use.
Thanks Geoff,
I see you have a couple of sections listed in your future builds. I could post a cross section I did a few years back if you are interested after the Pinta is finished.
Mike
Thanks Zoltan,
The Pinta is an unassuming small ship and would make a good ‘first build’ for any kit builder desiring to venture into the Dark Side.
Mike
Hi Mike,
I don't have enough words to express my admiration for your skill. I only hope I reach your level some day. Truly amazing build thank you for sharing.
JosephH said:
lookin good. mike where did you get the adjustable measuring bars for your gantry?
Joe,try here and print them
http://modelshipbuilder.com/e107_plugins/forum/forum_viewtopic.php?5572.post
Hi Joe,
The adjustable bars are shop made, they consist of two L shaped support legs with slots for attachment to the T-Track and adjustable horizontal bar. A horizontal beam is attached between the vertical support legs for stability and a thin moveable bar for vertical measurements. The measurements are based on the size of the board and model.
This is a photo of the plastic knobs I use in the track.
The link Zoltan posted will get you to the scales I just glue them to the vertical posts.
Mike
