Panart: San Felipe 1:75 Scale Build Log
Donnie
Well-Known Member
Madison, MS
I am using just plain (soft) solder for everyday basic electronic soldering. Thanks for the compliments. I switched out wire and did not use the brass, but rather some black annealed wire. I had to scrap off a little of the black annealing so the solder would stick. The solder joint is hidden within inside the channel "hole".
I am very tired of doing chainplates !!
Mike41
Well-Known Member
Moderator
Mike,
I took from "front on" photos and I think that I am ok. Another reason why I want to hurry up and get away from this thing.
Hi Donnie,
The angle on this photo makes things look a lot better, I would consider making a small “L” angle on the top of the chainplates for the first canon on the second row, just a thought.
Mike
Donnie
Well-Known Member
Madison, MS
Ok, here is the latest. Pictures speak for themselves. The Channels have a little bit more upward angle than I like. This was somewhat unavoidable. I have struggled with this kit trying to make the best of it. If you are reading this and you are thinking of buying the Felipe from Panart. DON"T !
Pat71
Well-Known Member
I like the result. You made the best of it. Hope my felipe turns out well. Gonna use your blogs for guidens and solutions if i get in trouble. Whats the next kit on your wishlist?
Donnie
Well-Known Member
Madison, MS
Eric, well, the Canons are a straight shot with clearance, yep, if pointed down, it would blast the heck out of the channel. It is OBVIOUS that this model will NOT be winning any awards any time soon. The problem is this: IF the Channels would have been mounted lets say somewhat parallel with the water line as most do, THEN the Cannon port lids WOULD NOT close !!! I would have had to close the lids that are all UNDER the channel. So as you can see, there is almost no way to do enough forward thinking on this model to avoid it. Unless you were to read the picture manual like a thousand times and foresaw the problem.
I am not happy with the results. It does not look good nor right. It is what it is though.
Pat,
I do not know. I was thinking about looking through ZHL, Marisella to see what I can find. To be more specific, I like the HMS Vanguard and the HMS Agamemnon, but I said to myself that I was going to try a ZHL POF next. This is not quite answering your question and I guess time will see. I just want to get this SF off my bench !!! I guess I could make the SF a hull model only, but that will drive me crazy it not being finished. No sails at all will be on this one and that should cut the time down considerably.
paulv1958
Well-Known Member
Melb, Australia
Hi Donnie, most builders would be extremely proud of what you have done. You have done a superb job with what you have. Its the Ship blues kicking in. The SA kit I'm doing has far less info than the Panart has, I'm having to make it up as I go along on a long for a of it. I now know why there re not may build logs of her.
Your patience and skills are superb. No kit is perfect. They all have have challenges. Boring otherwise. Keep chipping away. Look at what you have achieved & learned with the kit challenges.
Keep going.
eric61
Active Member
Deception Bay, Queensland
Hi Donnie, I remember saying the following to someone once before; nobody will inspect your model closer than six inches (and if they do drag them away!) The expression "Distance lends enchanchment to the view" is exactly that, only those madly interested in the hobby (like us) will give closer inspection and we don't critcsize unles asked for constuctive criticism.
Your model is fantastic given the time you took to build it compared to the Trinidad, YOU the MAN!!!
BTW, what has happened to the spell-check?
