Thank you Mustafa and Doug
Doug is it not that bad, just a lot of repetitive stuff. Once you realize a pattern, it is not that bad.
I used several techniques used:
- dip the end of each pre sharpened toothpick into the Poly Urethane and then hammer into hole
- used wood glue to do the same
- The final technique that was actually faster and better was just using plain CA glue.
Now onto the major decision of what to do with the Deck. Well, since the Deck was already laid down, I decided to be lazy (I know) and go ahead with it. But of course I was not happy with the laser cut / false planking "gaps".
Instead of re planking the entire deck, I decided to use a simple pick (with a very sharp point) and make indention's of a pattern. This was the best I could do with the false planking. I had decided earlier that I would do this.
The technique I used is a mixture of different things to achieve as close to a look as I could get. After making the indention's using a pick, I used a colored pencil (Black) and I scribed within the false gaps the colored black pencil. Then I used a Poly Urethane coat. Then I rubbed the deck using a paper towel which seem to make the blackened marks settle in the planking gaps. I did this several times until I achieved the darkness I was wanting. Then I used mineral spirits to clean up any residue and any unnecessary marks.
When I started doing this, I knew that I had made a fatal decision as it was not turning out like I wanted and I was making a huge mess. The Mineral Spirits helped get things a little more under control.
Oh well (sigh) it is what it is....
On a real ship, these deck treenails are not as visible as what is shown here. Any hole that is made on deck is going to be exaggerated when the Poly hits it.
