Well, to those - this is a warning: NOT do as I just did.......
Well, thanks Eric for the encouragement. However, this proves to me "again" to leave well enough alone. I should have progressed with the building of the ship instead of fiddling with the flippin' treenails. Now, I am stuck with going on ahead with the rest of installing treenails. Here's what happened: I knew I got started off in the wrong direction when I used Annealed Steel Wire (guage .03 mm) to use as "Iron nails" for the treenailing. I found out the hard way.
Even though the steel treenails were flush with the hull planking...DO NOT sand the side of the hull that has steel wire as the "dust" from the steel wire will EMBED itself into the hull planking and will give you a nasty blackend gray look of which I almost did not get out completely. This mistake is only at the bow covering an area of about 20 nails (40 mm of length at bow on one strip).
Then I realized that it looked awful, then I punched those out and started again. Well, by that time - trying to cover up for mistakes got out of control. I should have experimented on spare pieces instead of diving into it. But, I guess the thrill of taking a risk came back to bite me. But, then again, the wooden treenails made of simple toothpicks look pretty good, UNTIL I realized the misalignments. Oh well, another lesson learned to carry over to the next project.
I guess it goes without saying that I do not yet have the experience under my belt to handle all these situations. On the Trinidad, it never occurred to me to even put treenails on the side of the hull. However, I did on the deck because the deck was individual strips, but this San Felipe kit has so much laser cut pieces, you do not have any latitude to experiment and if you do, then watch out because the parts and pieces do not lend themselves to be tampered with too much.
I also do not like the tones or color vaiations of the wood chosen for this kit. The laser cut planking parts are of some type of ply that is ugly that do not match well with the other walnut. The walnut strips are also a variety of tones and do not match well. I feel like just chunking this thing and starting over.
