Minnie Sims Fishing Cutter 1/48 scale
neptune
Well-Known Member
Australia.
#1
I am reposting this build log , she is the South Australian Fishing Cutter, The Minnie Sims, 1/48 scale
Year or period represented: 1898-1932
History: Built as a local fishing boat in 1898 and wrecked on Kangaroo Island South Australia, while riding out a storm, the winds changed and drove her ashore after the Anchor gave way.
Scale 1/48, hull length 13 inches
Construction method / materials used: Jelutong was used for carving the hull, with Huon pine for stem, keel, stern post and deck planking, brass was used for the various mast and rigging fittings also the deck winch.
Research: The model was built for the grandson of the boats original owner, who supplied the plans and photo's of the boat.
neptune
Well-Known Member
Australia.
#2
This model was carved from two pieces of Jelutong as I do with most of my small models.
The hull was carved from two pieces of Jellutong, and glued together with a spacer the thickness of the keel in between, and dowells for fixing.
It was then carved and sanded with the help of cardboard templates.
neptune
Well-Known Member
Australia.
#3
The next set of pics show the hull carved down to the deck, the stem keel and stern posts being cut and also fitted and the false deck and planking being fitted, and also the cabin, if you have any questions just ask, best regards John. 8.jpg
neptune
Well-Known Member
Australia.
#4
The next set shows the cabin lights ( windows ), bow sprit, deck furniture, false frames and the gentleman I built her for. 19.jpg
Sgtmik
Active Member
Las Vegas, NV
#6
Ahoy Mate,
Nice looking ship. I have never built a solid hull ship and I wanted to know did you use chisels to shape the hull?
neptune
Well-Known Member
Australia.
#7
The tiller and winch,
checking the tiller for size prior to cutting
turning one of the winch drums
I cut the winch body out of some scrap brass, and used some rod and couple of gear wheels
from my scrap box.
parts painted ready for assembly
Assembled Winch
neptune
Well-Known Member
Australia.
#8
Sgtmik said:
Ahoy Mate,
:music-rockout: :handgestures-salute:
G'day Mike, and welcome I only used a craft knife and sandpaper as in the first pics, the wood is Jelutong and it carves very nicely,
best regards John.
neptune
Well-Known Member
Australia.
#9
Made a start on the masts and yards
I turned the masts and yards out of dowell
neptune
Well-Known Member
Australia.
#10
The hull painted and the mast and bowsprit attached along with various fittings
neptune
Well-Known Member
Australia.
#11
Shows the sails and mast sitting over the plan
I cut all the sails out of very fine cloth and made up the ropes on my ropewalk
neptune
Well-Known Member
Australia.
#13
And finally pics of her in her case which I constructed from pinewood mouldings and glass.
Thank you in advance for looking and if you have any questions just ask, its nice to be back aboard,
best regards John.
