- Aug 10, 2017
Hi Mike,
The 1/8” blade will turn in a smaller a radius than the ¾” blade, the ¾” blade is used for re-sawing thick stock into thinner boards.
Make sure you just have the blade tight enough to stay on the top wheel if it is too tight you will be buying lot of blades, also check the upper and lower blade guides when you change blades.
I made an auxiliary table with a zero-clearance slot for the blade, so stuff would not fall between the blade and bottom wheel. Cutting out deck knees and other small parts produces a lot of little pieces of scrap that can break a blade.
Mike
Mike
