LA SALAMANDRE, bomb ketch - POF - (CAF-models, 1/48)
Uwek
Well-Known Member
Moderator
Vienna, Austria
A small progress with my inside planking ...... not so easy, but with patience it is working....
View attachment 48525 View attachment 48526 View attachment 48527
Yesterday evening I needed 1 and 1/2 or 2 hours for only one row of plank, means four elements - very time consuming work.
Means I will need appr. 2 weeks for the inner planking (only on one side) - In the beginning I thought, that this ship will be finished in one year - no chance
ADC
Well-Known Member
I found it slow work too. I have 4 rows left to do on the starboard side which will now have to wait a month. These should be a lot easier than the middle rows. This hopefully should be the last of the tedious work until the rigging I hope .
Uwek
Well-Known Member
Moderator
Vienna, Austria
I am pretty sure, that before rigging starts, there will be other parts of the built also, which are tedious or feel like they will never end......and realy tedious is the inside planking for me not........it is taking very much time
So if I count correctly: my calculated 2 weeks for the insdie planking and you make in the same time four weeks a break - I have a real chance to overtake you in the work :cool::cool::cool:
Uwek
Well-Known Member
Moderator
Vienna, Austria
I am still working on my La Salamandre kit from CAF........but as I mentioned before (several times) - > it is slow motion and takes some time to install the inner planking. And now I know why other modelers making some building logs in chinese or russian foren are not showing these works very much in detail o_O
Today a short report how I did the widening from one plank to two planks, using half stealers.
........I am realizing now, that the last planking job I did some 10 years ago (due to my modeling break), so I have to come back into the routine in this work
-> If you see something which can be made better - please comment and give hints - I am happy to learn !!!!
To show the also my mistakes, during the planking:
The lower one was the first try - you see I thought completely wrong, means reverse and started to prepare the plank completely wrong - It took some time until I realized it :eek:
The middle one was the the second - fitted well, but too short on the right end, so I could not bend it over the curve#
The top one was the third and last one - fitting and possible to bend.
Drilling some holes with a hand drill in order to use small nails to keep the plank at the correct place and force the plank to keep the bending curve IMG_4338.JPG
Using wood-glue and prepared to take over the plank
Finaly installed plank with the nails and some wooden scrap sticks to press the plank down
Off course sometimes you have to take a look, how it would look like.......dry-fitted off course
Today in the evening I will make one more plank, and the next evening, and the next, and and and.......
Uwek
Well-Known Member
Moderator
Vienna, Austria
Before I continue with the installation of the insdie planking, it was time to mark some levels onto the frames, f.e. the bottom line of the beams, where the beams are laying on top of the deck clamps. First of all I checked the height of these points (keel bottom line <-> beam bottom line) and compared the kit´s drawings with the Boudriot drawings. I realized only very small differences (which can be already a result out of different the line thicknesses of the drawings) and decided to use the kit drawing measures.
Afterwards it was time to mark these heights inside the hull on the frames, so I can finaly calculate tapering of the missing planking.
For this I used this time an old device, which I got once from a modeling friend in Croatia....thanks Zeljko!!
As a horizontal level I used a strait wooden strip and checked for every use, that the strip is realy horizontal.
The height of the strip can be adjusted with two screw nuts on a thread.
The inclination of the thread and with this the horizonatl alignment of the strip can be easily adjusted with the knurled screw on the right hand of the photo
The strip has the thickness, here better width, of 1,5mm, so it can be laced between two frames of the hull. Here between frames 43 and 44 in order to mark the level of beam # 15 (see visible part of drawing).
The length of the horizontal strip has to be longer, than the distance between the two armes of each frame.
Finaly marked level of the bottom line of beams or the top line of deck clamps.....This way is off course only one way to mark different heights inside a hull.
Off course with this tool, it can be done only at P(lank)O(n)F(rames) models.......
Many thanks for your interest and visiting my Building Log of the 1:48 La Salamandre kit from CAF....... to be continued ....
Uwek
Well-Known Member
Moderator
Vienna, Austria
Today I received my ordered nails and wire to make the necessary nails and bolts on my La Salamandre.
I received copper, steel and brass nails in thicknesses of 0,6 to 0,9mm, also some brass wire with 0,3 to 0,5mm.
After some trials I will decide which one I will use for the different elements of the ship.
janos
Well-Known Member
Sydney
Uwe,
nice work!
I realised that at the inside planking you used both the English and the Dutch method to join the planks. Is this deliberately so?
Janos
Uwek
Well-Known Member
Moderator
Vienna, Austria
Uwe,
nice work!
Janos
Good point @janos !!
It is a french ship, therefore I can mix it ;)
Beside this joke: The inside planking will be 90% or 95% not visible and if, than the parts visible are only a very small area. Therefore my intension is in moment to cover the frames with a closed planking and I try to use planking techniques which are easiest possible to do at the local "problem" or situation.
Later on, especially at the outside planking I will follow the Boudriot drawings and use only the french techniques.
Peglegreg
Well-Known Member
Moderator
Central Coast NSW
For motivation and to get inspired
G'day Uwe
This is one thing that you don't need!
It might be good to look at when you're on your best 100 club tour, to keep your mind focus only.
Havagooday mate
Greg
Aginvicta
Well-Known Member
Moira N.I.
The inner planking looks really good Uwe, it may be slow progress but the results are worth it. What's the difference between English and Dutch planking?
Prost Andy
Uwek
Well-Known Member
Moderator
Vienna, Austria
Prost Andy
Many thanks for your positive comment - I am trying my best, therefore only a small progress every day.
A very good comparison is the Mondfeld sketch, showing on the left side the english and on the right side the dutch way.
Uwek
Well-Known Member
Moderator
Vienna, Austria
And here for comparison my planking. On the photo I marked the "dutch" way with blue arrows and the english with red ones.
I have also to admit, that I used at the case the english part until now only once, in order to adjust the planking, so that it is horizontal (the plank under it made a bow and was not strait horizontal)
