HMY Fubbs (1724)
Uwek
Well-Known Member
Moderator
Vienna, Austria
They are looking very good - and we can see that you can never have enough of these magnets !
I have also to order this tool !!!!
One question to the second photo:
Did you glue two planks one over the other , or did you sand them down to half of the thickness?
BTW: it is real good small tutorial - thanks for sharing the different working steps :cool:
Mike41
Well-Known Member
Moderator
Hi Uwe,
I have found the magnets very useful when building small deck items like the tops, well and shot locker etc. I do have a lot of them.
This is the procedure I use making the tops.
  • Cut planks to length plus 1/8” (for trimming) and glue up the four sections.
  • Mark the center section on each side of the top.
  • Using a small table saw (Proxxon) cut half lap at the ends of the sides and clean the joints with a file as shown in photo two and glue the rectangle together.
  • Using a pattern, I drill the holes and trim the top to size and add the banding.
This is not the fastest way to build a top but the results look good to me.
epicdoom
Well-Known Member
Baltimore, Maryland USA
Looking good Brother, How you like the Magnetic Table. I had one awhile back for plane building. sure made things easier to hold parts in place and way more durable then sheet rock and wax paper. and I didn't have a million pin holes in my wood from holding the parts down. The sheet metal got rusted when My basement flooded and I have been wanting to build another mag table.
Mike41
Well-Known Member
Moderator
Thanks, I use the magnet plate a lot.
I would suggest using navel jelly with steel wool to clean your plate then use paste wax to protect it.
Mike
epicdoom
Well-Known Member
Thanks for the Info. I tossed the Plate for the table as well as the magnets they were rusted badly. The Wax is a great idea and should also help prevent glue sticking to it. I'll have to run to the local sheet metal shop on Monday and grab a piece of sheet metal and get my table working again. I bought a bunch of the magnets last year, they are sitting on my bench.
Mike41
Well-Known Member
Moderator
Cannons:
The three pounder cannons are turned from ebony and the carriages are made from blood wood. Since there is only four guns shown on the model after turning the guns I made the carriages using hand tools.
This set of photos shows the guns in place.
IMG_4974.JPG IMG_4982.JPG IMG_4983.JPG IMG_4984.JPG IMG_4985.JPG IMG_4986.JPG IMG_4987.JPG IMG_4988.JPG
Mike41
Well-Known Member
Moderator
Thanks Dave & epicdoom,
I will be posting the masts and rigging next.
Mike41
Well-Known Member
Moderator
Rigging:
The model will show the standing rigging only.
The rope for the rigging is made from DMC cotton thread on a ME rope walk about ten years old a new rope walk is on my wish list. I am using 3 strands of no 8 for the lower shrouds and 3 strands of no 12 for the upper shrouds and backstays.
IMG_5013.JPG IMG_5014.JPG IMG_5015.JPG IMG_5016.JPG IMG_5017.JPG IMG_5018.JPG IMG_5019.JPG IMG_5034.JPG IMG_5035.JPG IMG_5036.JPG
DocBlake
Well-Known Member
Pewaukee, Wisconsin
Mike: What model lathe did you use to turn the cannons and mice? I have a Delta midi lathe better suited to full size turnings, but would consider smaller “model sized” one, or a mill.
Mike41
Well-Known Member
Moderator
Hi Dave,
I use a Proxxon DB 250 for small model ship parts, it works fine if you don’t overload the motor, it is very small. If something looks to big for the Proxxon it is. It is a lot of fun to use. I have an old Craftsman I use for larger stuff.
