HMS Victory 1:96 based on Shipyard
Paragraf
Active Member
#21
From the original model I used only the frames and the first white cover. The frames are glued onto 1 mm thick cardstock, the white cover is a paper (0.2 mm thick). If a part requires gluing, it is specified in the Shipyard's cut-out. Sometimes it is necessary to stick a part with 1mm thick cardstock, sometimes 2 mm. My friend from Poland is building a model only from a cut-out, without using additional parts as I did. If you are interested, here you can see how his work looks like http://www.koga.net.pl/forum/viewtopic.php?f=524&t=46286.
epicdoom
Well-Known Member
Moderator
Blandford Group Build
Baltimore, Maryland USA
#22
Thanx Brother I'll go check it out, but I really like your build especially all the filler between bulkheads it shows thought in a better end result. I would definitely build it with thicker stock laminated to the paper. Probably end up using wood on the moldings or build the paper up for the 3D look and Paint it the proper colors. This ship should be pretty large at 105CM length, I assume that's measuring the Bowsprit also do you have the Hull dimensions handy? if not down worry about. I think I'm gonna order the kit and also grab the Masts and sails kits as well for it so it will be a complete kit for the most part.
Paragraf
Active Member
#28
Thank you all for the compliments.:) I am glad that you like my work. The advantage of cardboard modeling is definitely that there is no dust.;) It also requires less expensive tools to make the model and less space for work. It's also cheaper then wooden modeling, though not as it was before.
Jimsky
Well-Known Member
Brooklyn, New York USA
#29
Another great example of what you can do with cardboard stock, patience and passion. Step by step explanation and use of custom jigs makes this build log very interesting. I like the idea of using the hypodermic needle as the treenail plugs. This is less time\material consuming compare to a traditional (toothpick dowels), and the output is great. Not to mention is more authentic as the plugs go alone the wood fibers. :cool:
regards,
Jim
