HMS Ontario 1780 scale 1:32 ( POB full version)
zoly99sask
Well-Known Member
Administrative
Moderator
Blandford Group Build
Hello Maarten,that part is done now ,at least most of it,I have tried to cut out the bulkeads on paper with a little knife and glue it on plywood but that method did not work for me well ,it was much easier for to use carbon copy.I do not have a laser printer though.
zoly99sask
Well-Known Member
Administrative
Moderator
Hello shipmates,after I finished shimming the frames above the lower gundeck to have the proper thickness I started the preparation to locate the gunports,I am also building a mock up guncarriage snd gun barrel for the correct elevation of the gunports.
Peglegreg
Well-Known Member
Moderator
Central Coast NSW
Hi Zoly,
Instead of carbon paper and if you have a laser printer you can just print it out on your laser printer and iron it on to the wood. You get an exact copy mirror image on the wood.
G'day Zoly
I know it's a bit late for you, but I print my shapes on a normal printer and use rubber cement to 'glue' the paper to the wood. There are no distortions as with white glue and it comes off very easily.
Happymodeling
Greg
zoly99sask
Well-Known Member
Administrative
Moderator
Hello Janos,I will use a wooden dowel and I will shape it ,one side will be narrower than the other like a regular canon.
zoly99sask
Well-Known Member
Administrative
Moderator
I have finished the muck up gun carriage and cannon and started to construct almost cube tubes for gun ports, these tubes will be sliced up to little thicker than the framings.
2018-08-22 13.02.34.jpg 2018-08-22 13.50.58.jpg 2018-08-22 13.55.28.jpg 2018-08-22 15.00.50.jpg 2018-08-22 15.18.39.jpg
Peglegreg
Well-Known Member
Moderator
Central Coast NSW
G'day Zoly
That's a great way of doing the gun port's trimming. I assume that you borrowed it from Janis from one of his builds.
Anyway it's brilliant mate
Greg
janos
Well-Known Member
Sydney
Looks good, Zoli! You just have to sand the tubes to the inside and to the outside of the frames. On the inside the planks go to the inside edges of the tubes, covering the tube fully. On the outside they have to be trimmed according to the overlap, by which the gun port covers will overlap the tube sides - plus some tiny gap of course to let the gun port covers to fit into the openings.
You misunderstood my earlier question. I meant how are you going to make the gun barrels (the final ones, not the one for the mockup). Turned of brass? Cast and painted? Turned of timber and painted? Or bought from a supplier?
Janos
zoly99sask
Well-Known Member
Administrative
Moderator
G'day Zoly
Greg
You are Greg,Janos told me this method for the gunports.
zoly99sask
Well-Known Member
Administrative
Moderator
Thanks guys for visiting my build log and the nice comments.
Janos,probably I will order cannons from Alexey Baranov.
zoly99sask
Well-Known Member
Administrative
Moderator
Hello shipmates,I have a big dilemma,does anybody know what is the correct positions for gunports?Are the gun ports are parallel with the water level or they are following the deck sheerline,what I mean the sides of the gun ports are perpendicular on the water level and top,bottom is parallel with the water level?
Hello @trippwj ,do you know anyting about the correct gunport linings follows the the deck sheerlines and some tilting are allowed for the gunports?
Thanks in advance!!
zoly99sask
Well-Known Member
Administrative
Moderator
These gunport installations are temporary ,nothing glued in yet and the sides are perpendicular to water level,top an bottom is parallel with water level.
ECCD2B4D-18B4-4B8A-8DE4-0C05394C4FBD.jpeg 4614CF6B-CE29-4A17-B241-FBA55CC9DB78.jpeg
Peglegreg
Well-Known Member
Moderator
Central Coast NSW
G'day Zoly
That's a very interesting question. I remember having this conversation with piratepete many years ago when I was a member of another forum.
Pete has written many articles and he told me and this makes perfectly good sense, it that the gun ports follow the line of the decking and is not square to the waterline.
The reason why it makes sense is that generally the Wales and the planking also follow the top decking.
Therefore, the vertical sides of the gun ports are NOT parallel to each other.
Hope this makes some sence
Happymodeling
Greg
Maarten
Well-Known Member
The Netherlands
Thanks in advance!!
Hi Zoly,
You are doing great, Like the results sofar.
To my knowledge for gun ports the sides are perpendicular to the waterline. The top and bottom however are following the shape of the deck line. On the inside there is normally one thicker plank fitted ( in Dutch weger) which was directly the lower edge of the gun ports following the rise of the deck.
Offcourse the British could do it differently.
Maarten
Well-Known Member
The Netherlands
Victory seems to have the same construction, see picture below.
You can clearly see the lower hull plank which is much thicker the the ones on top. This plank is creating the lower edge of the gun port following the shape of the deck.
