HMS Ontario 1780 - POB - scale 1/32
zoly99sask
Well-Known Member
Administrative
Moderator
G'day Zoly just been right through your log and enjoying it very much, I look forward to the rest of the build,
Best regards John
Thank you John for visiting my build log and for your positive comment!Once I finnished sanding off the hull I will start constructing the stern framings.
zoly99sask
Well-Known Member
Administrative
Moderator
Not an easy job but I think it will pay benefits down the line!
Even do the idea to use the foam to create a solid surface for the planking ,she will be fouble planked anyway ,using the first layer to get into of the “groove “ of planking and make a better job with the socond one.
Peglegreg
Well-Known Member
Moderator
Central Coast NSW
G'day Zoly
I believe a polyurethane glue is the best type to use.
This photo was taken from a video that use the insulation foam. And Luke on the video mentioned for best results use a polyurethane glue. This one swell up so be careful mate.
Happymodeling
Greg
ron0909
Active Member
Ottawa, Canada
What a creation so far! Good idea with the foam. It was a common solution for the folks building ships with card as without it the model would get that sucked in skeletal look between bulkheads. I imagine having a good even surface to plank against will make for perfect seams :) How many sheets of plywood did you end up going through for your keel and bulkheads?
Thanks for sharing this with us. I lived off Lake Ontario for 30 years and had no idea what the English or the Americans were building around here. Never too old to learn!
zoly99sask
Well-Known Member
Administrative
Moderator
Hello
Hello Ron,thanks for visiting my build log,I have used about 8-10 sheets of plywood(need to check the size) 6 mm thick.
zoly99sask
Well-Known Member
Administrative
Moderator
G'day Zoly
Happymodeling
Greg
Hello Greg,I never tried to use this glue yet,maybe in the future since all the poly foame glued in.
Pat71
Well-Known Member
Looks good to me but quite dusty in think rasping this stuff. Not working in livingroom in hope? Because of the temperatures here now i am alowed to work in livingroom with the airco but the airco blows the dust every where .
zoly99sask
Well-Known Member
Administrative
Moderator
Thank you guys for the visit and the nice word and likes,I will go over hull a few more times ,laying on a few planks to see if everything flush and even.
zoly99sask
Well-Known Member
Administrative
Moderator
Actually wasn’t that bad,everything went pretty smmothly,easy to sand this foam.
zoly99sask
Well-Known Member
Administrative
Moderator
I was just looking at your use of foam and it got me to thinking. I wonder if the expanding foam would be good for such an application.
I guess can be used the same way and just remove and sanding down the overflow.
