H.M.S Enterprise plank on frame CAF Models 1/48.
Here it is
http://www.woodmodelboatbuilder.com/index.php?main_page=product_info&cPath=1&products_id=262
Hi Brian
Both are very handy tools. I used bt dremel on the stand for part of my Triton. The Pensander is an excellent tool which I also used.
Cheers
Geoff
The kit instructions stated that I was to start making the centre frames and install them first, then work my way out from the centre to the bow and stern.
I was not sure about this, and decided to start at the bow and plank one after the other towards the stern. This way I can determine if I have been tapering the frames in the correct manner. Its my way of constructing the model, perhaps not the correct way, but it works for me !
Anyway, I commenced the stern galley construction. This is the most difficult part of the build so far.IMG_0038.JPGIMG_0037.JPG
I have to say, not convinced about the building cradle.
Sure, its strong and sturdy and holds everything together firmly, but I am having difficulty seeing if the frames are aligned accurately on the keel.
Also, building the stern galley framework is very difficult and I would think the Harold Hahn building jig would be far superior as a plank on frame format for this type of model.
Hi Brian, do you believe that if there were English instructions it would be a lot easier or is it just a very complex building system?
Oh , thats a difficult question to answer.
The instructions are in diagrams which are easy to follow if you are an experienced builder, but theres been some considerable head scratching on my part trying to figure out the sequence of assembly. I have been able to figure it out after studying the plans and looking at other plank on frame build logs of similar ships.
Most of the written text is in Chinese.
G'day Brian
It's great to see your progress in this increadale build.
The amount of time and dare I say, soul searching, must be enormous.
Fantastic work!
Havagreatsunday mate
Greg
Hi Brian,
Seeing your build on this model pushes me to build on my ZHL RC to get this Caf model as soon as possible.
I admire the plank on frame building and enjoy the realy nice wooden frame construction of the stern.
Keep up the good work, much enjoyable for us as viewers, but most probably more enjoyable to build it yourself.
Regs Maarten
Brian,
Great work as always. These Chinese kits are unbelievably detailed! Looking forward to seeing your progress!
Janos
Thanks for the comments guys, really appreciate your support.
Been busy again working on the frames and bending up the inner stringers for fitting to the frames which holds everything in place so I can pull the model out of the building jig.
I have been using rubber bands to pull back the top edges of the frames tightly against the framing jig with some additional clamps.
