Constructo 1799 Enterprise help
Sgtmik
Active Member
Las Vegas, NV
If you plan to rig sails and mount the guns you could show the gun ports open. If you don't have sails or they are not set , then perhaps the gun ports would be closed.
Pathfinder65
Well-Known Member
Maine, USA
Hi Mike,
Thank you for the comment. The gun port doors in the picture are a complete frame with a door that opens. I had just popped them into the
opening so I could get a picture and a feel of what they would look like on the hull
Pathfinder65
Well-Known Member
Maine, USA
Interesting aside:
B509B962-3608-4931-8B33-1F8C2396C684.jpeg Step #40, framing the interior of the gun ports.
6BE1F3D4-1F47-4881-9E5D-E0F83D8102E0.jpeg The pictorial instructions show the material for item #40, the thickness and width and cut length ( 1 X 5 X 12mm), the length of that material in the kit and the number of pieces to be cut (56).
But when one looks at the example picture of the gun port framing it is obvious that not all the framing pieces can be the same length. The horizontal pieces can be 12mm, but the vertical pieces length must be 2mm less. I think for this to work there must be 28 horizontal pieces @ 12mm and 28 vertical pieces @ 10mm.
Uwek
Well-Known Member
Moderator
Vienna, Austria
The correct measures you have to take directly at the gunports, one by one.
In prinpciple you are right, if the gunports are square with 12 to 12mm!
Pathfinder65
Well-Known Member
Maine, USA
Hi Uwe,
I've checked the cut profile plan and the rigging plan and the gun ports measure a nominal 12 X 12 mm. My gun port cutouts are approximately 10 X 10 mm. I did that in case I decided to use the commercial gun port frames in my post #180. I'm still thinking about that..
Uwek
Well-Known Member
Moderator
Vienna, Austria
Hi Uwe,
Related to the commercial gunports frames: they are not looking realistic if it is allowed to say....and this mainly because they are sitting on top of the hull planks. In reality the timber installed on the outside of the lids were exactly plane or on the same level like the hull planks. Means if the lids were closed, it was a more or less smooth surface. Also the timber of the lids followed the whales, not in your case of course.....I try to find a photo to explain it better.
Uwek
Well-Known Member
Moderator
Vienna, Austria
I found some photos of the HMS Victory which are demonstrating and showing what I wanted to express in my bad english
The lids are shaped to follow the curve of the hull. and no frame was visible from outside, when they were closed
Pathfinder65
Well-Known Member
Maine, USA
View attachment 40714 View attachment 40715
Hi Uwe,
Thank you for the excellent explanation and examples. I think I now understand how this should be modeled.
(BTW your English is much better than my German)
Pathfinder65
Well-Known Member
Maine, USA
Gun Port Framing:
Yet another “how does one do this”. I’ve spent some time on the Forum reading build threads and looking at how the members tackle build problems.
I started to experiment cutting scrap pieces to the size recommended by the build instructions. Each gun port requires two pieces 12mm long and two pieces 10mm long. The challenge was to have square ends. First I tried cutting a piece to length with a razor saw. Holding the piece down and cutting at the same time wasn’t the answer. The sawed end wasn’t square. Off I went to the Hobby store and bought a modelers miter box made out of plastic. This time I clamped the scrap piece in the miter box and sawed away. The result was the same as my first try, the sawed end was not square and the sawing action deformed the vertical slot in the miter box. I ordered another modelers miter box, this time made from Aluminum and several saw blades with more TPI, thinking that would provide a finer precise cut.
The result was about the same as my first two tries. The miter box has one extended leg, I had to clamp on a end stop for the length of the cut, clamp the scrap I was cutting, etc. The scrap piece cut to length was almost but not quite square.
Another internet search for a tool to better do the job resulted in this find.
There were several styles available, I chose this one because of next day delivery. The little pieces on the right side of the cutter are 12mm and 11mm long. The cuts are square, and I can cut as many of the same size that I need without much effort.
Not bad research for a guy who recently celebrated his 55th anniversary of his 21st birthday, EH.
Pathfinder65
Well-Known Member
Maine, USA
Another interesting build instruction error:
I’ve been working on framing gun ports most of the week and thought I might do something else today. I skipped forward to instructions for the hatches. The instructions for cutting the pieces for the smaller hatch at the bow are at odds dimension wise with the deck plan.
The the instructions show the thickness, width and length of the material as well as the number of pieces required.
The picture above shows the forward hatch build. The problem with the build as shown is when parts #84 ( 1.5X5X12mm) are placed inside of part #85 (1.5X5X20mm), parts #83 (2X4X15mm) are 2mm short of filling the frame made by parts #84 & #85.
The test of the theory is shown below. I placed the partially completed hatch on the deck plan and found the dimensions on the plan were not the same as the build instructions. The orientation of the top and side pieces was also different.
My fix will be to trim the extra 2mm from the longer side.
Pathfinder65
Well-Known Member
Maine, USA
The Hatch:
After a day of measuring, cutting, fitting, sanding and fitting this is the result.
A little more sanding and this piece will be done.
I’ve also learned to double check the instructions for a build part and double check the plans to verify dimensions.
Pathfinder65
Well-Known Member
Maine, USA
More how do you this.
I looked at the build instructions for the gratings and decided that process was simple enough. I glued together three sets and noticed that the grates had to fit into a 21mm by 65mm and 21mm by 26mm frames. But, the grating edges extended beyond the dimension of the frames.
So, another “jig”. Blue masking tape and a mini saw. I found by using a little Bees wax on the saw blade the cuts went quickly without any binding.
E736BB05-E01B-41D9-BD96-060748E0A359.jpeg EC9C8316-5E6F-4E3A-AE8A-90B1535BB588.jpeg
As Uwe has noted several times, this is a great learning experience for a novice builder.
Pathfinder65
Well-Known Member
Maine, USA
Capstan and ladders:
Had little bit of time today, so I worked on the capstan and ladders. Both little builds went quite well with one exception. The build instructions for the ladders are off by one step. The instructions show seven, but the side frames provided allow for only six.
Pathfinder65
Well-Known Member
Maine, USA
Another little foible:
This little build looked simple enough. I made the platforms and then looked at the barrels. One end was a shown in the build instructions but the other end has 1mm or more indent. The choice was to sand that end or fill it. I chose the latter. I found some old Balsa filler in my RC airplane flying box ( another old hobby). We will see how that works.
Pathfinder65
Well-Known Member
Maine, USA
More Tools: Sanding Detailers.
I discovered these while ordering some #11 cutting blades. I had made some sanding sticks from 3/8 X 3/8 square birch stringers. Those have worked very well. However these detail sanders looked like they might work for some of the smaller details in the build.
I’ll let you know how they work out.
Pathfinder65
Well-Known Member
Maine, USA
