Colonial Schooner Hannah by Cap'n Rat Fink - 1/4" scale - semi scratch - Mario
Uwek
Well-Known Member
Moderator
Vienna, Austria
#41
A very good progress you are showing. And what you are showing us looks realy good. I hope to get with my Salamandre a similar quality.....great work.
teleman
Active Member
California USA
#43
Thanks Uwek. I try to give as much info of my building process as I can. So if others have questions I had hoped with my detailed explanations I could answer some of their questions. When I read some build that have very good details it helps me a lot. There are builds that really great work but not much explanation how did it and I wish they had.
The practicum is very good. But I treat any practicum like the "PIRATES CODE". It's more like guide lines. I go by what it says and at times I go with what feels right for me to get it done.
Doc thank you! The big difficulty with this kit is the jig. The jig is nice, but once you get to a certain point it has to go. Hahn's jig the model is left in during the planking. I had to remove it because i could not put the Wales on. Most of the hull and the deck will be planked.
The Lumberyard does carry this kit. But no practicum. I had to purchase the hahn's plans to assist me with the build.
Thanks for stopping by
Mario
teleman
Active Member
California USA
#45
Last of the deck framing is done, with the completion of the last ledging and the breast hook combination at the bow.
Now for the poop deck framing. For the stantions I first make small cuts into each frame with my rotary tool. it makes it easier then starting with an exacto knife. the rest of the cut is done with an exacto saw blade. Then finished up with manicure files.
Now I was going to continue on with the Poop Deck. But Mark Taylor from MSW presented a question to me. Did the Hannah have a Orlop deck? I offend wondered about this. Did Hahn omit this from his model for the simple reason he was construction a model simplified for the first time POF model builder? I don't know. I hope Dave Stevens takes a look here on my build log and maybe answer my question here. Hahns book does stated the Hannah was basicly build from examples from the Halifax back in 1775 I think. I still have access to the hull interior, so I am tempted to do this if I can get clarification on the interior of the hull.
I also wondered about hanging knees and where would they be located at and the lodging knees. The ships smoke stack....there has to be a lower deck where the stove is located. Am I correct about that???
IF ANYONE CAN HELP ME WITH THESE QUESTIONS PLEASE CHIME IN. BECAUSE THAT WOULD BE A LOT MORE FUN WITH THIS MODEL!!!
I added a picture of the Halifax to help with these questions.
I have the Poop Deck ready to go. But going to wait a little bit to see if I get any answers to my questions .
teleman
Active Member
California USA
#47
I was planning on stopping on the Hannah a bit after I completed the Poop Deck framing. I wanted to start another scratch build. I have a buddy who wanted to build a model boat so i gave him one of my kits. He is a good model builder, but never made a boat. I gave him the kit under the condition I got the box , book, and plans back unscathed. So he made copies and wrote all over his and cut out portions out to do his build. He did a great job. So I am going to start making the build board will I hopefully get my questions answered on the Hannah. here the book.
didit
Active Member
#48
hummm I do not know what they are telling you at MSW but an "orlop deck " is the lowest deck in a ship of 2 to 4 decks. The Hannah had one deck so the simple answer is no there is no orlop deck in the Hannah.
Hahn did not omit the orlop deck because there wasn't one in a single deck ship like the Hannah. To understand the work of Harold Hahn you have to know the reasons and thinking behind each model he built. Each and every model serves a purpose and details were added or omitted depending on what the final goal he had in mind. There was no need to add unseen details below deck because they simply added nothing to the final display of the model.
Hahns book does stated the Hannah was basically build from examples from the Halifax back in 1775 I think.
The Hannah built by Hahn is a reconstruction based on general building practices of the period and what plans did survive. Hahn spent a lot of time with guys like Howard Chapelle and others to come as close as he could to the appearance and construction of colonial ships. Harold work and research was very accurate. Harold's model building had a certain degree of artistic license.
In the case of the Halifax the concept was to show the interior of the hull so all the detail was included.
here is a drawing of a typical schooner of the time period of the Hannah. There are a number of wrecks of the period that were studies and all of them were built the same. What you see at the stern is the cabin floor which is the same as you see in the above photo of the Halifax.
here is a ship wreck of a later period but it shows the cabin floor. The cabin floor and an orlop deck are totally different things.
note in the above photo the one and only set of hanging knees, for the most part hanging knees were not found in North American shipwrecks and rare to be used in small vessels like a schooner. If and when a hanging knee was use like in the above example they were placed under a load bearing beam like the beam that supported the front of the cabin. Looking at the drawing you might find a hanging knee below the double deck beams at the break of the main deck or under the beam that supported the windlass. other than that hanging knees were not used
to build ships from the Hahn collection or from his research material as he stated himself " my research work, models and drawings are a starting point for the serious builders. There is room for improvement as new information comes to light."
Hahn expected the builder to have a basic understanding of the subject and how these ship were built.
didit
Active Member
#50
Harold was an engineer by trade and he thought of everything when he developed his building method.
yes he did think of putting the hull in a lower jig like a cradle BUT as you found out you have to remove the hull in order to add the wales and planking. Once you remove the hull from the jig it is no longer held stable. With Hahn's method the hull framing is held in place by the jig until the wales and planking can be added, thus the hull is now sturdy and stable.
another reason to extend the jig above the hull is as you build the hull and once all the frames are in place you can sand the hull while it is held in a jig.
teleman
Active Member
California USA
#51
Thank You Big Time didit! I think this would be Dave. Your the only person I know who know Hahn very well. There is a lot to learn on Colonial Schooner's. I do have Howard Chapelle' book also. Thinking of adding a little more detail in the hold and stern area for the fun. Never have seen the model Hannah with the extra detail. Anymore info will help me a lot. thanks again. You just made this build even more fun to do.
Uwek
Well-Known Member
Moderator
Vienna, Austria
#52
Many thanks for your time and the detailed explanations......very informative and interesting -> Great
