G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #21 Here's how I rounded the square blocks: Last edited: Aug 21, 2018
G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #22 I needed to replicate these plates on the single trees: So I used my cutting machine to to cut out the shapes on a very thin brass sheet: Last edited: Aug 21, 2018
G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #23 I also needed to replicate these details on the end: Here is the unpainted product:
G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #24 And then the finishing process begins: Primer Color coat: End Detail: Final details:
G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #25 On to the double tree: Here I'm trying to replicate this top plate. Didn't quite get the same shape.
G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #26 Here I try to replicate this bracket which holds the single tree to the double tree on the front and a chain to the front axle on the back. I start with this thick brass wire: Then I flatten, file and bend it to the shape I want: Here's a dry fit onto the end of the double tree: Here's the single tree attached to the double tree with the bracket. Last edited: Aug 21, 2018
G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #27 There is a step on each end of the double tree: Here's my version:
G grayson72 Joined Oct 18, 2017 Messages 21 Points 48 Location Sacramento, CA Aug 21, 2018 #28 Putting all the pieces together after paint: Steps and pinstriping added: On the model: Last edited: Aug 31, 2018
Uwek Administrator Staff member Administrator Forum Moderator Joined Dec 25, 2017 Messages 31,144 Points 1,238 Location Vienna, Austria Aug 22, 2018 #29 Great work - it is looking very realistic
Pathfinder65 Joined Jan 23, 2018 Messages 4,525 Points 688 Location Maine, USA Aug 22, 2018 #30 Wow, great attention to detail.
Peglegreg Staff member Forum Moderator Joined Jul 30, 2017 Messages 1,653 Points 488 Location Central Coast NSW Aug 25, 2018 #31 G'day grayson Just found you very interesting and amazing log. Love you attention to the finer details. Looking forward for more. Happymodeling Greg
