Bridge and Boat Diorama
Swabbie
Well-Known Member
Australia
#21
From Masonite I built the road base, curbing, and footpath onto the span.
Chiselled out trenches for inlaying wires for the navigational lights, and contacts, located under the span.
Drew up a template for making the span framework from 6 mm square Tasmanain Oak. Wires will be routed along the vertical beams of the frame (they will go to the span hut). Doweled the framework to the span.
During this time I got the idea for making the cable anchoring points to the span frame. I soldered half a fishing swivel to the 3 mm bolt heads. The swivel will relieve any twisting of the cables.
Swabbie
Well-Known Member
Australia
#23
Finished the framework. Now for the span hut. The hut base plate has three balconies, and gangways. Used 3 mm MDF.
Used matchsticks for railing posts. The extra plate on the base is the hut floor. It also serves as a guide for attaching the hut walls.
Added the cable anchoring points. Included longitudinal bumper rollers, made from microswitch actuator arms, to stop span getting caught up with the tower framework. Added a photo-coupler to trigger the vessel traffic lights (on the span). Once the span has reached the top of the tower a blind fits between the U slot to cut the light beam across the U. This then triggers the vessel traffic lights to change from red to green.
The wires have been routed along the framework and through the hut floor.
Swabbie
Well-Known Member
Australia
#24
Added lateral bumper rollers. Now the span ought to be guided to freely raise and lower without getting caught up on the tower somewhere.
Vessel traffic lights were attached and wires added and fed into span hut area.
Balcony assortments. In real life, both (A) and (B) boxes contain gearing and winches for operating the span cable drive. The span motor is in centre of span hut. Differential axles go to each box. The other boxes contain (as far as I know) an auxilary generator, and stores for maintenance.
Swabbie
Well-Known Member
Australia
#26
Thank you @JosephH for your compliment. And @zoly99sask for the 'likes'.
__________________________________________________________________________________
The span hut was next on the agenda. Made from 3 mm MDF, 2 mm clear Perspex for windows, and white card board for window frames and doors.
Mixed a jar of grey enamel paint that matched the actual bridge, and started to paint the span.
Completed the gangways. Used fly screen for wire meshing.
Found washers that fit nicely over the nav LEDs. Now they look like bezels. Added road and footpath railings.
Swabbie
Well-Known Member
Australia
#28
Thank you @zoly99sask for your "like".
Now that the actual bridge towers are built, a more tangable approach to designing the pulley wheel system was available.
First of all, I did not like the pulley wheels that were on the market, so I decided to make my own (iIf only I had a lathe) out of washers. Which I sweat-soldered together.
Then I designed and built the brackets to hold the pulley wheels.
I was pleased with the way this all turned out.
Swabbie
Well-Known Member
Australia
#34
Thank you @zoly99sask. Just a reminder, I am posting piecemeal to catch up to where I am at with the project, so it may appear that I am going fast.
Before installing the towers I realized that I won't be able to remove the span for any repairs/miantenance once the towers are installed. My solution was to replace one set of fixed lateral bumper rollers for removeable ones.
Made a road base and drilled numerous holes for rail posts. Prepared wiring from traffic lights and span contact points. Installed the road base together with the traffic lights and bridge towers. Then gave the road another coat of paint.
Sutton. Ontario, Canada
#35
Hello Peter
Just found your lift bridge, Golly but you sure got your hands full when you took on this huge project. I am very much impressed with all of that detail and electronic circuitry that you seem, to handle so very easily. Just love your layout with all of that detail and all so very realistic, Well Done.
I used to watch these types of bridges go up and down as we traveled on the seaway in Ontario, Canada many years ago when I worked on the ships, always found them very interesting. Thanks for giving me a whole new prospect on just how they operated, ENJOY.
Regards Lawrence
Swabbie
Well-Known Member
Australia
#36
Thank you @zoly99sask, @Uwek, and @Canoe21 for your 'likes' and kind words.
_______________________________________________________________________________________
The next step took a few days to build.
Installed all the rail posts using matchsticks, all marked for railings and cut to size. The railings are from bamboo skweres split in half.
The gaps seen near the traffic lights are for the swing gates (which close across the road).
Swabbie
Well-Known Member
Australia
#38
Thank you @lauckstreet Bob for your kind words and interest, and @mrshanks for your 'likes'.
___________________________________________________________________________________________________
I had a few loose wires under the display table and they needed to be identified and terminated to some degree.
Tilted the table on its edge and proceeded to tidy the wires up.
All wires go the the control box area.
Those white cards under the table are stoppers for when I insert the fender piers later on.
This was a good opportunity to paint the underside with acrylic sealer undercoat.
neptune
Well-Known Member
Australia.
#39
G'day Peter, well I don't know, you call this a diorama, I think it is more an exercise in Engineering, Technical Development, it is absolutely unreal, and the way you have adapted different materials and items, I'm really enjoying this build, I look forward to seeing the bridge rising and falling,
best regards John.
Swabbie
Well-Known Member
Australia
#40
Thank you @neptune for all your 'likes' and kind words. I too am looking forward, though with some apprehension, to seeing the diorama working well.
Painted the railings.
Painted the cement. Believe it or not, it took me a while to decide on the most appropiate shade of grey to immitate new cement.
The bridge will not show any weathering. I want it to look brand new, pollution free, like they do for architectural displays.
