44 Gun 2 Deck Frigate Roebuck (1774) 1:48th Scale
JosephH
Active Member
#61
hehe thanks Uwe.
Today I got all the floors adjusted and all the notches cut out for the gun ports. so as of now the fronts are finished I will still have to do the bevels but the majority is done. Tonight and this weekend will try to get the aft sections done.
Things left to do before I can start playing beaver:
1: Finish Aft sections
2: Bevel Frames
3: Create Bow and Stern Frames
4: Create Transom area and Wing and filler Transoms
5: Use all the above to make my individual Backbone parts
6: Start cutting wood
7: Break stations into individual parts while glue dries
JosephH
Active Member
#62
Thanks Uwe
2: Bevel Frames
JosephH
Active Member
#63
Sooo I had to cut abt 5 hrs overtime today so they told me head home at lunch tonight so i cut 4 hrs plus an hour for lunch and they let me have an hour OT. I am not complaining I usually get abt 15 hrs overtime a week most the time so I sat back for a bit tonight and got 15 aft stations finished only abt 40 more to go counting the doubles as there are 46 aft stations and several of them are doubles
JosephH
Active Member
#65
so last night did the first 15 aft frames, however I noticed I forgot some notches etc in the other for the gun ports so everything is adjusted and here is what it looks like right now
#67
lol I have acess to all stuff I need as I used to work for a kit manufacturer so I can get whatever I need made. what I need is better images of the figurehead and the stern carvings
on another note I am an hour or two from being finished with all the flat stations
#68
So tonight I got all the aft stations finished next I will try to Loft the Bow to come up with the front frames and Hawse Timbers
I also have to finish cutting the Gun Ports in the aft Timbers
#72
as can be seen I made 7 Buttocks and there is some tweeking to do to the front, I also need to double check where the flat deck starts height wise
#74
so wasted all day trying to get the bow section lofted up etc but so far just a bunch of headaches. thats the sad part of design sometimes you waste an entire day and dont get anything accomplished
JosephH
Active Member
#76
well I hit a road block on the Roebuck having trouble with the bow and stern stations and need to smooth the inside out it is close but not quite correct. so will have to loft the inside. I am doing the Orlop Deck but noticed the inside isnt quite right so guess things going to slow down while I try to adjust a few things. I might need to move on to another section as I been getting frustrated and wanting to just fiddle with meaningless little parts like capstans etc that I dont need to right now. how do you get past the frustrations and want to continue with a project? usually for me it is move to a different area however until I get the frames finished I cant even really do that due to needing the frames in place for reference and with DaveF in hospital etc and not able to help i am back on my own again. I was thinking maybe if I went to 2D I might be able to get it but need to learn to do it 2D in order for it to be of use again no mentor so its just trial and error
JosephH
Active Member
#78
thanks Regs I am not sure was thinking old fashioned way but with about 1020 parts just for all the stations I may have them laser cut just will take a while when finished to set up the cut files and make printed templates so I know which parts are which when they come back.
JosephH
Active Member
#79
well today spent some time relofting the bow section and it doesnt look too bad I may have it figured out Just will have to thicken the cant frames tomorrow after work and hope they turn out ok
JosephH
Active Member
#80
ok so I got my fwd Cants not sure though. I have the shapes but they look like too big gaps maybe I need to taper them having them thicker on the outside tapering in to the keel? or are they normally the same thickness as the rest of the stations as I made them here? either way at least I got the hard part out of the way getting the shapes. so finally sorta unstuck
