17th Century Battle Station
DocBlake
Well-Known Member
Blandford Group Build
Pewaukee, Wisconsin
Mike milled the frames before I could let him know of an option we could include. Looking at Goodwin's book "The Construction and Fitting of the English Man of War ,1650-1850" the frames would have been bolted together, with a prominent scarf joint just below the level of the weather deck . The first photo from Goodwin's book shows the layout. The second is what I plan to do with the exposed frames: a simulated scarf joint and bolts. The question is, how big 17thframes.jpg top timber.jpg would those bolt heads have been? Goodwin gives no clue, and I couldn't find the answer in Steel's book either. Anyone hazard an educated guess?
Uwek
Well-Known Member
Moderator
Vienna, Austria
In scale 1:48 I try usually to make the nail head between 0,5mm to max 0,8mm, sometimes for deck planking 0,35mm. The rule by Boudriot is, that the head should be max 1/4 of the thickness of the timber fixed......I would suggest to try 0,5 and 0,8 and decide what is looking best....
didit
Well-Known Member
Sponsor
I have several drawings for bolts and drift pins for wooden ship building I will look through my archives and see if I can find more of the drawings dated circa 1800
if I remember correctly J. Humphrey may have given specs for the bolts in his day book
didit
Well-Known Member
Sponsor
just a quick peek I found several references to bolts. Now I see why a scale or dimensions are not on the drawing it is because the specs are in the text.
if you read through all of the text you may find references to bolts and their sizes once you know the dia. then you can figure out the head and nut sizes off the drawings.
didit
Well-Known Member
Sponsor
well it is better than just a random guess at least this is a historical reference to using bolts in wooden ship building.
if you want to go through this page by page Model Ship Builder has a transcribed version
DocBlake
Well-Known Member
Pewaukee, Wisconsin
Thanks Dave! I checked out Humphrey's notebook. For a vessel of 50 guns, 1-1/4" bolt diameter was specified. Base on modern bolt head to shaft ratios, the bolt head would have been about 2" in diameter. Answers my question!
DocBlake
Well-Known Member
Pewaukee, Wisconsin
In looking at the frames above you notice the difference in the color of the cherry between the two. This is fairly typical of cherry. Since these two frames are a focal point, I want to make sure that they look similar. I use a special stain mix of standard and gel cherry stain on full sized furniture. It works great even on lighter cherry sapwood. I think I’ll give the frame on the left a swipe!
