1/144 XXI U-2540 Submarine. Another one?!
Swabbie
Well-Known Member
Australia
#63
I wish to create a mini-diorama in the battery compartment. A dramatic scene could be based on a dangerous situation is of a compromised battery: where leaking sulphuric acid reacts with salt water to release chlorine gas. This gas has a distinct yellow-green colour to it. The diorama is about a crewman investigating battery damage.
Glued and soldered two LEDs together which share a common cathode lead (earth). Had to file some of the plastic away first. Then soldered leads to the them. Installed the LEDs to the top battery bank. They are hidden, and hoping the two colour lighs will meld together. If not, I may have to use a medium that will aid in the blending. Anyway, much of the projected outcome won't be known until everything is in place. Fine-tuning will be inevitable for such a cramped dark space as the battery compartment.
While playing around with the battery banks I realised that there is a wall missing. It is part of the battery bay. Added more styrene.
To help increase light onto the subject, the back wall (hull) and ceiling got a coat of white gloss paint. Will add another coat tomorrow.
Altered one of the figurines to look as it he is creeping along the low central gangway, while holding a torch. Optic fibre is used for the torch. Eventually the LED and fibre will be blacked out, only having the light coming out of the torch end. Drilling into the LED to have the fibre inserted, and wrapping in foil really intensified the light through the fibre. It should look okay in situ.
Swabbie
Well-Known Member
Australia
#66
Thank you @Fright and @Donnie for your complements. Thank you @dj56 , @Fright , @Uwek, @zoly99sask , and @Pathfinder65 for your 'likes'.
________________________________________
Well, today was the last day for the putty delivery with no show, and now is Friday evening. I promised myself to start back onto the Bridge Diorama on Monday. Want to finish the Wardroom and battery compartment by then. Will have to go and buy some car body filler tomorrow to finish that compartment.
Today, I focused on the bulkhead between Control and Wardroom. Decided to have the Captain stepping through the bulkhead door. Chopped two figurines to swap legs, and chopped an arm to re-position it.
Used a few decals, and again I wished I didn't. You may not notice it but my hand is getting steadier. I am relearning how to manipulate the brush and paint consistency to improve the outcome.
Swabbie
Well-Known Member
Australia
#67
Thank you @Uwek , @Pathfinder65 , and @Fright for your 'likes'.
___________________________________________________________________--
Well, my audacious cross-section plan did not turn out as well as I hoped. The main reason is that the cross-section is 2D on a 3D model. Meaning, there is only one point in space to view the cross-section correctly. It was a valuable lesson. A cross-section on a 3D model has to be 3D to work well.
The cutaway does show what the batteries look like, to some extent. Decided against painting, or installing mini connecting leads. It looks already busy as is.
This section of compartments is complete (three done, four to go). The first section, the conning tower, is still not finished. Hoping to have that complete tomorrow.
As you can see, there is some sort of drama depicted in the battery room. Besides leaking chlorine gas, there appears to be a man overcome by the gas.
Swabbie
Well-Known Member
Australia
#71
You have a creative imagination Peter and the skills to make it happen. I must watch the film Das Boot again they had a gas leak on that Sub,
Cheers Andy
Thank you Andy for complement.
Yes that is a fabulous movie. Watched that one a few times. Can't believe that the actors remade the whole movie in English. The red headed guy never spoke English before and you can tell.
Yes they did have chlorine gas emissions (seawater reacting with sulfuric acid) after receiving heavy damage.
Uwek
Well-Known Member
Moderator
Vienna, Austria
#72
The model of the U-Boot which was used for the film can be visisted in the "Bavaria Filmstudios" better "Bavaria Filmstadt" in Munich, Germany.
It is very interesting to see and walk through the 1:1 model which they used for the film sequences inside the boat
This is the big model they also used
and here you can find a research for photos of the models
https://www.google.at/search?q=bava...Mu7nbAhWG2qQKHVMGAWQQiR4IlAE&biw=1920&bih=900
Sorry Peter for high-jacking the topic.....I thought this could be interesting for you and some members....
Swabbie
Well-Known Member
Australia
#73
Been busy on another ship, a ship I believe would not be suited here. A total ad-lib scratch build space ship :D. Guess what, I really am enjoying it. Why? Because there is not one single rule, laws of physics, expectation, ought or should-be attached to it. It is absolute liberation. Pure creativity. I believe every modeller should give it a go. It unleashes the imagination and the child within _ to run amuck without judgement.
Anyway, I forgot to add a photo to the last update. Nothing new here, just another angle of perception.
Swabbie
Well-Known Member
Australia
#76
Well me ship maties, it is a sad day indeed.
For a few days now I have been fiddling around trying to make the turret guns look as if they were firing. Used the optic fibre idea, as previously mentioned in another thread. I cut the barrels off, drilled holes to insert pointed optic fibers. All went well until I tried to attach LEDs to the ends of the fibres. Man, it's a small space in that conning tower. After much manipulation of LED leads I finally got LEDs to contact the fibre ends. I think I fractured one fibre; its pointed end could not be well illuminated.
Okay, so I got them to work using my multimeter to power the LEDs, but the meter's battery was running low. So I used a 5 volt source, which means that the LEDs need a resistor to bring the voltage down to 2-3 volts. So I added the resistors. Then I did something out of character for me. I connected the 5 volts to the wrong end of the resistor. In other words, I added 5 volts to the LEDs, I think they lasted 1/10 of a second. Blown the LEDs.
Oh well, that was a short lived experiment. This one blow up in my face due to unawareness. The application originally worked. I was going to have the gun ends flashing. At this moment I am tempted to forego this application, because I really have to replace the fibres in a way that won't be so difficult to add LEDs. But I don't know how I am going to do that (yet).
In the meantime, my plan is to just paint orange-red tips at the ends of the barrels.
Fright
Active Member
Atlanta, GA
#77
So sorry about this lighting mishap.o_O Your detail work on everything and all of your lighting has been amazing! I'm positive that, with your skills, you'll be back in business in a heartbeat. Here's to those 'silent' killers!
Swabbie
Well-Known Member
Australia
#78
Thanks Fright.
I will return to this build, but have other commitments at this present time. This model, with two others, are on rotation.
Have been considering cutting out the gun axles and replacing them with scratch-build sets. Will experiment first. If I can make them to flash well, then I will install that. If not, then I'll replace the original set (hopefully nobody will notice anything different.
