How do you bend your hull planks?
Discusses Hulls, Mast & Deck Furnishings
User avatar
GaryM
Senoir Chief Petty Officer
Re: How do you bend your hull planks?
Post by GaryM » Wed May 09, 2012 1:41 pm
The secret to using the iron is to not just heat where you want the bend but to heat the area around it. You can feel the plank slightly bend and you can use a light pressure to continue bending. Then take it of the bending jig and finish by hand and hold until cool. For limewood, it bends very fast. The harder the wood, the more important it is to heat the adjacent area.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
CharlesEdward
Petty Officer Second Class
Post by CharlesEdward » Wed May 09, 2012 2:16 pm
Thanks Gary, I will indeed try to use it again soon. I just hate to spend money on some tool and NOT use it at all. I read the instructions but don't remember warming the area around the bend. I will take your advice and instructions to heart and try it this weekend. I wonder where I put that darn thing? It couldn't be in the tool box could it??
JohnK aka Charles Edward
Current builds: Montanes, Albatross; Sao Miguel; Albatross; Wappen von Hamberg; Royal William.
Completed kits: Santa Maria; USS Dallas, Scottish Maid; Half Moon; Golden Hind, Yacht Mary; HMS Sharke.
User avatar
JeanPierre
Seaman
Seaman
Post by JeanPierre » Mon Feb 25, 2013 10:52 am
I know I will not convince any of you, plank wetters or plank heaters, but on my current model, I do all my bending with my devoted Amati nipper. It is fairly quick, I don't burn or boil my fingers, and I don't spill water over the floor. Also, the terrible "dead cow effect" which happens when (mainly first planking) planks are glued in place when still wet, is something I don't have to care about.
I send a few pics: on one of them you see the well known tool with a plank ready to be glued in place. The 2 other pics speak for themselves.
1/ a thorough sanding/filling session still has to be done;
2/ the 6mm wide kit planks I was stupid enough to use for the 2nd planking. I wanted the planking to follow the ship's lines and of course they were way too wide and too stiff to allow pretty steep lateral bending. So I cut the planks lengthwise in two with a little jig of my own. As I hope can be seen, the plank nipper allows such bending too, with a little care of course;
3/ the "reverse" bending at the rear implied that I either soaked the planks which I did not want to do. As this part of the ship is under the waterline, I can always choose to paint it off white after filling up the nipper indents. I don't know, but the indents can be seen on the picture, and in my opinion tyhey are not too obvious and can be dealt with later on
4/ You may notice that the lower, part of the hull, still under construction, has a much better finish than the upper part. What I did is (of course) put a sufficient amount of white glue to the side of the planks, lay them down on the hull and sand the joint after removing the excess glue, thus before pinning down the plank. The idea is one I found on a French forum where a modeller said he used a mix of sanding dust and white glue to fill up any gaps in the planking, rather than wood filler, which never has the right colour.
In fact I still have to test with my tube of wood filler: the one I use is exactly the right colour when applied, but turns into a much paler brown when sanded. Tests will show if it gets dark enough after I apply the wood sealer.
Whaler 056.jpg (119.41 KiB) Viewed 1910 times
Whaler 055.jpg (114.14 KiB) Viewed 1910 times
Whaler 054.jpg (112.48 KiB) Viewed 1910 times
Post Reply
Return to “Hulls, Mast & Deck Furnishings”
