Darron's over 90% scratch build: Sovereign Of The Seas 1:84
This Forum is all about building your ship from pure scratch, with the aid of plans, or even heavy modification or kit bashing. All can be found here.
User avatar
Darron
Seaman
Seaman
Re: Darron's over 90% scratch build: Sovereign Of The Seas 1
Postby Darron » Sun May 04, 2014 12:48 pm
Hi Shipmates! :cool:
Thank you Steve! I do like to play around with graphics and photo's.
First I had to remove the stern planks that I used last time to demonstrate what can happen if you don’t shape the planks enough at the stern as you curve planks around the transom, this build calls for a flat transom with the hull planks ending on the edge of the transom not curving around it and so these planks are removed.
I used a temporary strip of 6mm wood pinned to the false keel were the stern post will be, this will keep the planks on the transom the right distance apart and level with the keel as it did before when I did the stern part of the gallery. Once the transom was totally planked I used a profile gauge to match both side of the transom as I sanded the planks to shape, check all the time so as not to remove too much.
Image Image
When the shape of the transom was right I cut-off the pin heads filed them flat to the transom, I started to re-plank the stern of the ship allowing the planks to overhang the transom, once the glue had set fully I cut the excess off and sanded the edge of the plank to the transom.
Image Image
Well the planking continues!
Darron
Image I might not be able to see what I'm doing, but I have a feeling it's RIGHT!
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Sun May 04, 2014 7:20 pm
doing a great job....the planking looks real good ;)
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Sun May 04, 2014 7:27 pm
Great idea of using the contour gauge to balance the sides.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
Return to “SOS Build Logs Scratch or from Plans”
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
