Building the Medium Clipper Glory of the Seas.(kitbashed)
This Forum is all about building your ship from pure scratch, with the aid of plans, or even heavy modification or kit bashing. All can be found here.
User avatar
rwiederrich
Petty Officer Second Class
Postby rwiederrich » Thu Jun 20, 2013 2:37 pm
There are no versions of Donald McKay's Glory of the Seas available in large scales..so I did the next best thing.....I kitbashed the hull of the 1/96 Revell Cutty Sark and then scrach built the rest.
Current builds: 1/96 Medium clipper Glory of the Seas
1/96 Ferriera...AKA Cutty Sark
1/96 clipper Donald McKay
1/96 clipper Western Shore
User avatar
rwiederrich
Re: Building the Medium Clipper Glory of the Seas.(kitbashed
Postby rwiederrich » Thu Jun 20, 2013 2:43 pm
Much hd to be change..removal of the anchor skids..and the rake of the bow. the Cs is extremely sloped where as the Glory is very vertical...
I had to build up the bullworks to correct the hight of the gunwall.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 2:48 pm
The bowsprit and jibboom needed to fashioned and the bow mods recoppered...a new monkey rail added. the location of the howes hole needed to be relocated from the cheek to below the cheek knee.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 2:51 pm
Then the entire hull painted to mimic the weathered munx medal sheathing.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 2:54 pm
Gunwal changes had to be made and bracing and supports added..along with a new cap rail. I added new wood decking as well...weathered too.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 3:11 pm
Next..I had to select some maple veneer for the forcastle and deck houses.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 3:13 pm
then I built the forcastle deck. I used plans drawn by Michael Mjelde..author of several books on the Glory of the Seas.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 3:17 pm
The next trick was to create the figurehead. The original is in the china house club in NY......so I had to once again go to the drawings and images. I had to first cut the beak back to create the seat and pedestal she would stand on...like the actual ship. I made the figurehead from scratch.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 3:22 pm
Lots of work was put into altering the CS bow so it replicated the Glory bow.
Here are plenty of more scratch built items. The windless and windless winch...ladders and catheads and forward capstan.
User avatar
rwiederrich
Postby rwiederrich » Thu Jun 20, 2013 3:26 pm
Shifting aft..I had to build up the new poop deck and add the aft rail.
Return to “SOS Build Logs Scratch or from Plans”
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
