Polacca XII century
This Forum is all about building your ship from pure scratch, with the aid of plans, or even heavy modification or kit bashing. All can be found here.
Tadeusz
Petty Officer Second Class
Polacca XII century
Postby Tadeusz » Sun Apr 14, 2013 1:24 pm
Hello,
My new project is model of sail ship polacca ( or polacra) in scale 1:100.
Plans from polish monthly Modelarstwo Okrętowe (ships modelling)
A polacca is a type of seventeenth-century sailing vessel used mainly on Mediterranean.
It is three mast ship with square sails on main and mizzen ( sometimes on mizzen was gaff or also lateen sails ) but lateen sail on foremast.
For this size of hull the best way is solid hull made as “bread and butter”.
It is staple wood boards with thickness equal to distance of waterlines shaped as waterlines to be glued together and finally shaped according frames stencils.
On beginning after scanning halves of waterlines and frames to be converted to full waterlines and frames. Waterlines glued on cardboard to be used for transfer to hull material i.e. MDF board.
Tadeusz
Let's power of glue to be with you.
My models:
From kits
Vasa, HMS Victory, Le Solei Royale, Friesland
From scratch
HMS Warrior 1860, Esplanade, Grosse Yacht
Norman’s ship, HMS Speedy, La Royale
Peter von Danzig
viewtopic.php?f=59&t=404
Current project:
Polacca XII cent.
Polacca
Polacca (Kopiowanie).jpg (69.63 KiB) Viewed 6604 times
IMG_3175 (Kopiowanie).JPG (47.11 KiB) Viewed 6604 times
IMG_3177 (Kopiowanie).JPG (58.21 KiB) Viewed 6604 times
http://www.modelarstwookretowe.pl
Modelarstwo Okrętowe (Kopiowanie).jpg (68.16 KiB) Viewed 6604 times
User avatar
popeye
Master Chief Petty Officer
Contact:
Re: Polacca XII cetury
Postby popeye » Sun Apr 14, 2013 6:40 pm
looks like a very interesting build......I'll look forward in seeing your progress.
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
Tadeusz
Postby Tadeusz » Sun Apr 14, 2013 10:26 pm
I am sorry for mistake - polacca was used in XVII century. :text-imsorry:
This was due to celebrate the end of the previous project. :auto-ambulance:
Tadeusz
cog
Postby cog » Mon Apr 15, 2013 12:32 am
Celebrating a bit to much ;-)
It still looks like a nice build. Looking forward to read more on your progress
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
Next build: (on the shelf) Arno XI
User avatar
otrax01
Petty Officer First Class
Postby otrax01 » Mon Apr 15, 2013 10:58 am
Tadeusz, I think I understand when you say solid hull, but Bread & Butter is beyound me, so I'm looking forward to this build because I'm sure to learn something here. I like the look of the plans.
Kent
Remember, When your out in the shop, Ship Happens!
___________________________
Finished Builds: Le Mirage by Corel
Current Build: HMS Victory by Mamoli
Tadeusz
Postby Tadeusz » Mon Apr 15, 2013 4:59 pm
How to make a sandwich.
Tadeusz,
My models:
From kits
From scratch
Peter von Danzig
Current project:
Polacca XVII cent.
hape of watrlines transfered on MDF board - hull material .
This is our bread.
IM003309 (Kopiowanie).JPG (55.62 KiB) Viewed 6584 times
Bread must be cut into slices.
First we use the circular saw.
IM003310 (Kopiowanie).JPG (82.21 KiB) Viewed 6584 times
Next cut shape of slices with use the bandsaw.
IM003313 (Kopiowanie).JPG (45.68 KiB) Viewed 6584 times
The edges of the slices are machined with rotary file.
Holes for centering dowels are drilled in each slice.
IM003314 (Kopiowanie).JPG (58.52 KiB) Viewed 6584 times
Edges are rounded with use of table sander.
Our bread is ready to meet butter.
IM003315 (Kopiowanie).JPG (103.07 KiB) Viewed 6584 times
Preliminary dry assembling.
IM003311 (Kopiowanie).JPG (84.16 KiB) Viewed 6584 times
Slices of spread with white glue
(butter), our sandwich ready.
Bon appetit.
IM003316 (Kopiowanie).JPG (68.65 KiB) Viewed 6584 times
User avatar
otrax01
Postby otrax01 » Mon Apr 15, 2013 5:33 pm
Now I see what your doing. Nice trick there. Thanks for the info
Kent
Tadeusz
Postby Tadeusz » Sun May 05, 2013 12:29 pm
Hi,
The progress of the model is not satisfactory but started season of works in the garden which can not wait.
Despite of this I have already finished and painted hull and part of the equipment.
Tadeusz
Hull ready for bulwarks installation.
IM003318 (Kopiowanie).JPG (76.27 KiB) Viewed 6520 times
Groove in the bottom for inserting of the keel.
IM003319 (Kopiowanie).JPG (87.17 KiB) Viewed 6520 times
Bending of the bulwark rail wtih mould use.
IM003321 (Kopiowanie).JPG (68.49 KiB) Viewed 6520 times
Boiling of wooden strip for bending.
IM003322 (Kopiowanie).JPG (73.88 KiB) Viewed 6520 times
Bending on the mould.
IM003324 (Kopiowanie).JPG (105.53 KiB) Viewed 6520 times
IM003337 (Kopiowanie).JPG (94.17 KiB) Viewed 6520 times
User avatar
popeye
Contact:
Postby popeye » Mon May 06, 2013 6:38 pm
looking very nice.....deck layout looks superb!
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
cog
Postby cog » Sat May 11, 2013 4:23 am
Nice job on the rail Tadeusz, I tried it on the Dolphyn, but I couldn't get it to bend. It cracked, splintered and broke. Finally, from sheer frustration, I cut it out ...
She is looking better, and better!
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
Return to “SOS Build Logs Scratch or from Plans”
Who is online
Users browsing this forum: No registered users and 1 guest
