Lauro Passenger Liner Roma
This Forum is all about building your ship from pure scratch, with the aid of plans, or even heavy modification or kit bashing. All can be found here.
1492
Seaman
Seaman
Postby 1492 » Mon Feb 18, 2013 7:38 am
Hello all, this is my first build log on this forum.
After many months being absent from my workbench for personal reasons, I have finally made a return to the tools. A special project has arisen that I have promised my better half I would build in time for her parent's anniversary of their arrival to Australia from Italy in 1965. The Project will be the Immigrant/passenger ship Roma.
A brief history with some background of the ship can be found HERE
The ship will be built to a scale of 1/365, mostly because that scale fits perfectly onto an A3 piece of paper when I print the plans.
The plans for this ship were near impossible to find, however thanks to our member Bob Wilson (Shipbuilder on this forum) I was able to make a start with the deck plans he so generously sent to me. I was also able to get my hands on the hull plans from here (a C3 hull) as the detail was much better especially since I was to use the Bread and Butter technique that was taught to me by Bob's Manual Miniature Steam & Motor ship Construction. At this point I would like to thank Bob Wilson for the support and guidance he has given to me and the inspiration he has provided to change me from a person who believed ‘I could never do that’ to a person who is willing to give it a go. After reading both his manuals I gained the confidence and began to feel that what was previously impossible can now be done. Although it would seem that I followed Bob's chapter on the Kenya build, the truth is that all the manual's tips and construction guides helped immensely.
So onto the build:
Piece of wood marked with the centre lines and guides, I have also marked the deck plans with the corresponding guide lines. The profile plan is glued to the wood and has already been marked where the decks will be cut.
Here I have used the bandsaw to cut excess timber using the glued plans as a guide. I have left the bottom as extra depth. You can see the errors I have made with the deck lines (crossed out)
The decks are cut out using the correct drawn lines. Ready to have the deck plans glued on each piece.
The deck plans are now glued on to each cut out.
Decks cut using bandsaw and glued together using the guides drawn on the plans
John
shipbuilder
Petty Officer First Class
Contact:
Re: Lauro Passenger Liner Roma
Postby shipbuilder » Mon Feb 18, 2013 8:18 am
His John,
Good to hear from you again. I was wondering how you were getting on with the Roma! and now here she is and looking well! That was an interesting link to the aircraft carrier, because my first ship was one of them (HMS Premier) that had been converted back to a merchant ship (Rhodesia Star) after the war, but I had never seen the plans anywhere of the ship as an aircraft carrier.
Bob
rummy
Seaman
Seaman
Postby rummy » Tue Feb 19, 2013 7:06 am
Very nice work.You make it look so easy. Larry
With age comes wisdom.I'm still waiting.
Builds Complete:1819 Virginia,King of the Mississippi,Constellation,by "AL"'
Builds I'm working on:Syren by "MS",San Felipe.
Scratch Builds: Triton Cross Section
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Tue Feb 19, 2013 1:23 pm
Hello John,
Welcome and good luck with this build.
It's a very nice gesture to make this for the Admiral's parents.
Now Bob has a fellow model builder. In this category that is :D That's great.
Thanks you for sharing and take care,
Anja
Those we loved but lost are no longer where they were,
but are always where we are.
Current build - De Halve Maen by Corel
viewtopic.php?f=52&t=235
Completed : Albatros 1840 by Constructo
1492
Seaman
Seaman
Postby 1492 » Tue Feb 19, 2013 8:25 pm
Hi Bob, Larry, Anja
Thank you for your support, it is appreciated as I've never made anything as complicated as this ship.
John
John
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Postby Sjors55 » Thu Feb 21, 2013 10:06 am
Hi John,
Also from me welcome.
If you have questions about your build, ask Bob :-)
I can not help you because my ships are a little bit bigger,
I will follow you with this one.
Sjors
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
viewtopic.php?f=52&t=279
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Thu Feb 21, 2013 6:34 pm
welcome to the site. looks like a really neat build you have there.....I'll be looking in on this one
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
1492
Seaman
Seaman
Postby 1492 » Mon Feb 25, 2013 5:36 am
Thanks Sjors, I know Bob can be relied upon to help me with this build. He has already helped me tremendously.
This weekend I spent a lot of time sanding the hull to as close to the final shape as possible. It meant a lot of elbow grease and measuring and more sanding. It's quite exciting to see a ship's hull appear from inside a block of wood.
First I glued the lower inner plan to the bottom of the model. I then began to sand the wood no further than where the pieces of wood met (marked with the red lines) as the guide. I also glued the bow and stern profile taken from the plans to a piece of copper plate and cut them out.
I decided to add some detail to the stern profile and rudder.
After getting close to the final shape. I used these guides (taken from the plans) to get an accurate shape. I marked the decks with the location for each numbered guide found in the lower part of the image. I Marked the bottom of the hull with the place and number for the guides found at the top of the image.
John
shipbuilder
Contact:
Postby shipbuilder » Mon Feb 25, 2013 5:56 am
John,
It is coming along very well now. You will soon be on the more interesting part of fitting out!
Bob
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Mon Feb 25, 2013 12:04 pm
Hello,john,
The hull is shaping up nicely :D
Thanks and take care,
Anja
Return to “SOS Build Logs Scratch or from Plans”
Who is online
Users browsing this forum: No registered users and 2 guests
