Spanish Schooner Franca XVIII Century 1:50
This Forum is all about building your ship from pure scratch, with the aid of plans, or even heavy modification or kit bashing. All can be found here.
User avatar
JScolum
Petty Officer Third Class
Postby JScolum » Sun Mar 25, 2012 1:48 pm
Model similar to Polacra Venus but without of square rig .Start 30 October 2011 . Not finished
kosz bok.jpg (41.13 KiB) Viewed 4534 times
kosz z góry dalej.jpg (53.39 KiB) Viewed 4534 times
roboczo calość tyl.jpg (71.9 KiB) Viewed 4534 times
kadlub od tylu nadbudówka.jpg (34.93 KiB) Viewed 4534 times
zblizenie poklad.jpg (93.41 KiB) Viewed 4534 times
cały pokład.jpg (34.21 KiB) Viewed 4534 times
gotowa ława.jpg (63.64 KiB) Viewed 4534 times
gotowa łąwa 2.jpg (57.04 KiB) Viewed 4534 times
ławy 1.jpg (82.55 KiB) Viewed 4534 times
I used bamboo from old paper spherical Ikea.One lamps they are very cheap and this bamboo serves me also after soaking for making slats about different shapes
I stuck black paper intended for pictures. He worked great since contains tarry supplements. Practically it left like in the original: -) much worse would be to make it alone with false deck
It is an original colour of wood. It is American cherry treated with oil with wax. Black wood is Wenge
User avatar
JScolum
Re: Spanish Schooner Franca XVIII Century 1:50
Postby JScolum » Sun Mar 25, 2012 1:51 pm
It should be at the beginning but with difficulty. There will be a mess
DSC_3880 (1).jpg (52.56 KiB) Viewed 4533 times
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Sun Mar 25, 2012 8:57 pm
very nice.......you have a good command with your planking skills. I still have a problem with glue spots when I try staining.....it's a splendid looking build.
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
User avatar
JScolum
Postby JScolum » Mon Mar 26, 2012 4:20 am
I glued the second layer to cyjano acrylic glue . After bending wet from times I still glued the wet surface. Water is acting as the accelerator for this glue. Stained wood is becoming coloured to such a colour alone like after putting oil. Such a technology is suitable for applying in elements to which they won't be stained.If we are going to stain one should make it before the adhesive bonding (in case of every glue should this way become which can get wood in) If below 1 mm used the veneer of the thickness I perform the adhesive bonding to glue of the adhesive bonding of the footwear. The same what in the cardboard modelling is used, and what's more there is the entire magic. If some cracks came out I am putting in of not an ordinary wood adhesive (transparent white) and I am grinding silting cracks. Then I am putting varnish or oil with wax.
User avatar
popeye
Contact:
Postby popeye » Mon Mar 26, 2012 4:56 am
I plank with the wood still wet {damp}...I find that it does the bends I need a lot easier. I use white glue....I try to wipe up the excess without spreading it and then wipe it down again with a second {cleaner} cloth. you would think that after sanding, it would remove it......I still get a little here and there. I am getting better at it though. I have another build that I am doing called the Gothenborg, which is the only one I've don so far that is stained. I double planked it to be able to stain it..it came out real good.
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Postby Sjors55 » Mon Mar 26, 2012 11:52 am
Hi Leszek,
It's hard to keep up with you my friend.
You have so many builds going on. And they are all beautiful.
But it is a pleasure to read them and look at the pictures. Thanks!
Sjors :auto-driving:
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
viewtopic.php?f=52&t=279
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Mon Mar 26, 2012 1:19 pm
Hello Barba,
A great looking ship. And our planking looks superb :handgestures-thumbupleft:
Take care,
Anja :happy-sunshine:
Those we loved but lost are no longer where they were,
but are always where we are.
Current build - De Halve Maen by Corel
viewtopic.php?f=52&t=235
Completed : Albatros 1840 by Constructo
Return to “SOS Build Logs Scratch or from Plans”
Who is online
Users browsing this forum: No registered users and 1 guest
