Hms Investigator, 1800, 1/48 scale built by neptune from plans by Robert Sexton.
This Forum is all about building your ship from pure scratch, with the aid of plans, or even heavy modification or kit bashing. All can be found here.
Moderator: zoly99sask
Post Reply
neptune
Petty Officer First Class
Contact:
Post by neptune » Tue Jun 13, 2017 9:25 pm
This is a compacted build log of HMS INVESTIGATOR, 1800, 1/48 scale from plans by Robert Sexton.
This is the Investigator that Mathew Flinders used during his charting of the Australian coast in 1802.
I built this model for a gentleman who does talks on Mathew Flinders and his charting of the Australian coastline.
shows the bulkheads being erected
the rest of the bulkheads cut out
the side elevation
stern view all the bulkheads in place
bow view
head on view
stern framing, the plywood piece will be cut away along with the tops of the frames later in the build.
shows how I did the rabbett, I cut a strip not as wide as the keel and glued it in place
then the keel went on top
shows how the first plank will sit in the rabbett
this is the strip in place and also note how I thinned the deadwood area so the planking will run flush into the stern
post.
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Re: HMS INVESTIGATOR, 1800, 1/48 scale built by neptune from plans by Robert Sexton.
Post by zoly99sask » Tue Jun 13, 2017 10:15 pm
Hello John ,I will follow this with a great interest!!
neptune
Contact:
Post by neptune » Tue Jun 13, 2017 11:06 pm
Bow timbers being cut and checked over plan
the rudder
the rudder and stern post
stern post and keel fitted
fitting the stem note the wood dowells through the keel and also the stem.
fitting the scarph piece
fitted and sanded
neptune
Contact:
Post by neptune » Tue Jun 13, 2017 11:15 pm
my fancy plank bender, an old coffee pot with everything removed except the element.
Frames marked for the wales position
end of wale nibbed to fit in stem rebate
first wale in place
another view
the second wale plank being fitted
another view
neptune
Contact:
Post by neptune » Tue Jun 13, 2017 11:30 pm
Fitting the wales continued fixing with PVA glue and dowells
how I used the clamps as I worked back along the hull
another view, after glue and dowelling to six framesI then started on the port side wales.
Both sides glued and dowelled to front six frames
Starboard side view, note the timber clamped to the front of the wale for extra support while the glue drys.
neptune
Contact:
Post by neptune » Tue Jun 13, 2017 11:37 pm
I'm afraid I dont have any pics of the planking of the hull, just the completed planking, I lost the log when MSW crashed and these are all I managed to salvage, if you have any questions just ask.
the plan held against the hull
The gentleman I built her for wanted some of the framing exposed, so this is what I did.
neptune
Contact:
Post by neptune » Tue Jun 13, 2017 11:39 pm
view along the deck getting ready for the cabins, take note that after I had planked the hull I cut away the timber tops along the main deck level and also the quarter deck and added another layer of planks make sure when you do this that the second layer over lap the frst layers joints.
shows the cabins part framed
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Thu Jun 15, 2017 3:55 pm
Nicely executed.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
neptune
Contact:
Post by neptune » Sat Jun 17, 2017 8:34 am
GaryM wrote:Nicely executed.
Thanks for the nice comment Gary,
best regards John.
neptune
Contact:
Post by neptune » Sat Jun 17, 2017 9:20 am
These next set of pics show how I made the capstan, its made out of a piece of Australian Pear, the pics are pretty self explanetary,
It seems like a bit of an overkill, but at the time I had just bought the lathe and I wanted to see what it could do
Turning down to size
Lots of chippings
To get the openings for the capstan bars I ran the end of the dowell across the saw table after working out where to put the cuts, any questions just ask.
best regards John.
turning the lower barrel the top barrel was turned the same.
Top cap turned to size
turning the bottom cap and drilling the hole for the top barrel to fit into.
checking against the plan
the top and bottom parts
Milling the whelps.
The double capstan temporarily assembled.
Post Reply
Return to “SOS Build Logs Scratch or from Plans”
