Naomi South Australian Fishing Boat 1/24 scal2 by neptune
This Forum is all about building your ship from pure scratch, with the aid of plans, or even heavy modification or kit bashing. All can be found here.
Moderator: zoly99sask
neptune
Petty Officer Third Class
Contact:
Postby neptune » Tue Jun 13, 2017 12:12 am
This is a small fishing boat that was built for the same family as the Mini Sims, see my other build log,
I built this model for the same gentleman that I built the model of the Mini Sims for, only this time he did'nt have any plans for her, however he did have the dimensions and photo's of the original, so I built from these, I enlarged the photo's to the size of that the model would be and worked from them.
The model is built the same way as the other small models I have built, ie, hull carved from solid pieces of Jelutong,
starboard side after carving and sanding, shown sitting on photo, I did'nt show the carving process as it is shown on my other builds.
shown laid over the photo, I did'nt have any plans to build Naomi from just a set of photo's the gentleman lent me.
another view of the stern
With the two halves joined with the keel between.
neptune
Contact:
Re: Naomi South Australian Fishing Boat 1/24 scal2 by neptune
Postby neptune » Tue Jun 13, 2017 12:21 am
Carved hull comparing with photo
Carved Hull sitting over photo
viewed upside down
starboard side view.
neptune
Contact:
Postby neptune » Tue Jun 13, 2017 12:33 am
I used my Proxxon milling machine to mill out the areas for the cabin etc, you can also see the plywood spacer between the two hull halves, this pic was taken before adding stem keel and stern post.
Starboard side view
These next four pics show the planking and dowelling
neptune
Contact:
Postby neptune » Tue Jun 13, 2017 12:48 am
Next up was the cabin assembly,
I used plywood for the carcass
then I added the the cabin top and the sliding hatch, then I planked it with Myrtle, added the well details and lined the cockpit
neptune
Contact:
Postby neptune » Tue Jun 13, 2017 1:03 am
 Next up was the propeller, I had a small one that would fit but wanted to try out my MF70 Proxxon mill
I started with a square piece of brass plate and drilled a hole in the middle to hld it tight and to also connect to the shaft after shaping.
then I cut a circle
then I shaped it, using cutting discs and files.
I then used a rotary tool with an abrasive disc to form the angles of the blades
Finished prop
another view
and attached to the boat.
neptune
Contact:
Postby neptune » Sun Jun 18, 2017 9:26 am
Rudder and tiller
most of the deck work finished
to make the mast hoops I wrapped some brass wire around a dowell
and the cut through the wire with a dremel disc
hoops have been soldered
in place on mast
the boat with the mast, bowsprit, cat head and the horse on the stern
neptune
Contact:
Postby neptune » Sun Jun 18, 2017 9:37 am
after completing the painting of the hull.
attaching the main sail to the yards
attaching the halyards etc
sail raised, she vwas a stump masted vessel they sailed her without the top mast in place.
overall deck view
neptune
Contact:
Postby neptune » Sun Jun 18, 2017 9:54 am
Just about to connect the rudder
I made up the small grappling anchor from brass wire
Close up view
two views looking down on to the deck
And two views of her in the case I made.
Thank you all who have viewed my build, I hope you enjoyed it as much as I did building her.
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Sun Jun 18, 2017 6:07 pm
She sure looks good in the case. The machine parts you made from scratch are inspiring.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
neptune
Contact:
Postby neptune » Sun Jun 18, 2017 8:51 pm
Thanks Gary, I enjoying building these little boats with a solid hull, its very relaxing work,
best regards John.
Return to “SOS Build Logs Scratch or from Plans”
Who is online
Users browsing this forum: No registered users and 2 guests
